Results 1 to 9 of 9
Thread: Pump Electric Advice
    May 2010
    Default Re: Pump Electric Advice
    Since your original circuit has a 15 amp breaker, I can only assume that this circuit is using 14 gauge wire, but you didn't mention how far this circuit run is from the breaker panel to the outlet where the extension cord is plugged in, or if there are other outlets on this same circuit. In all likelihood, you could have a slight amount of voltage drop before you ever get to the extension cord. Like Al said your bigger motor may require a bigger circuit. You might want to consider installing a complete new circuit with the proper rating for your new motor.
    pratzert is offline Lifetime Member Thread Analyst pratzert 0
    Thanks for all the info.
    It sounds like I would be better off returning this pump and getting a 1HP with a lower AMP use rating.
    It would avoid all these problems and having to add another outlet with a new 20AMP breaker.
    Just ain't worth it. Back to Namco it goes.
    Honesdale PA
    With the smaller pump you'll be happier every month too.....when the electric bill comes.
    Quote Originally Posted by Poconos View Post
    No arguement there !
    Thanks.
