Thread: Liner pulled out in corner, appears to be no track
    Default Re: Liner pulled out in corner, appears to be no track
    What little I know of liner tracks is that the corner, which is curved, is a separate piece from the straight lengths that run down the sides. There's usually an extra hunk of white rubber, about 6-10" long, jammed in the track AFTER the liner goes in call, fittingly, "liner lock".
    Ohio, North Canton
    Carl, I think the "liner lock" you are talking about is a piece of rope material that is jammed between the coping and the top of the lip of the liner. I have rope stuffed in 2 of the corners, and multiple coins stuck in the other 2 corners. Does this sound about right for what you are talking about???
    Well, after further examination the track piece in the corner is definately broke off. I can see what looks like a piece of cast metal up near the coping that has a 1/2moon break on it, and can feel junk down in the area in the corner between the liner and the pool wall.
    Is this something that a novice like me can repair, or do I need to call in an expert????
    Thanks,
    Ted (TRHOD) North Canton, Ohio
    1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
    Acquired pool June 2006 Been BBBing ever since
    For liner locks, i have this now to prevent, hopefully, liners falling out of the track.
    Ohio, North Canton
    My problem is not so much the liner lock, my problem is the 90degree track that is underneath the corner coping cap appears to be gone.
    Has anyone tried to replace this corner track????
