Results 11 to 20 of 24
Thread: Small Pool, Cloudy Water
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Default Re: Small Pool, Cloudy Water
    Mike, if you test with the 10ml sample, you'll use less of your reagents. BUT, by doing so, you'll only be able to test at .5 ppm resoultion (.2 is more 'accurate' than .5). That being said, .5 is fine IMHO.
    PS, when you put the powder in, if it turns pink with one scoop that's all you need to use (save the other scoop for your next test )
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    Jun 2010
    Phoenix, Arizona
    If that's really so, that would save a lot on the powder. When I first started using the kit about two weeks ago, I looked on Taylor's website, and they have instructional videos for testing. With the FAS-DPD test, the demonstrator showed that he was putting in two overflowing scoops, in fact it ran way up the handle, and they said that it didn't matter if they were larger, but they said nothing about being smaller. It made me scratch my head watching that, because what's the difference between two level scoops and one overflowing?? So I've been doing two level carefully to conserve, but if one level works, that's even better.
    Dan
    10,000 in ground, concrete w/PebbleTec surface, waterfall
    420 sq. ft. cartridge Pentair filter, In-floor popup cleaning system, 2-1 hp pumps (1 for popup system)
  1. Water problems in small, small pool
    By MikeFromMesa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2013, 04:53 PM
  2. Filling a small pool with iron well water
    By newbiepool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 05:24 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Small, Shiny Specks in pool water?
    By wposton84 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-22-2011, 12:26 AM
