Results 1 to 10 of 24
Thread: Small Pool, Cloudy Water
    Jun 2010
    southeast
    Default Re: Small Pool, Cloudy Water
    Yeah.....not green anymore! Its back to the milky white that I posted about at the start of this thread.
    The shock is sodium dichloro-s-triazinetrione 15%. Other 85%.
    I ordered the kit. Could you point me to the skimmer sock setup? This pool has no skimmer. I vacuum with the SIMPLE 15.00 water hose rig and a pool net.
    I'll have a real pool someday!
    Mike
    Skimmer socks won't work if you don't have a skimmer. Basically a skimmer sock is a little sock that you wrap around the skimmer basket to help catch little stuff. If you have no skimmer, no need for skimmer socks.
    You know what? I think if this was my pool that only held 1000 gallons, I'd just dump the water and start over. You are going to really struggle to clear it I think with no skimmer and most likely an inadequate cartridge filtration. Dead algae is most likely not going to be caught in that vac net thing.
    Now that you know how fast an algae bloom is gonna start in your hot climate, just be diligent about chlorination so one can't get started. You've ordered the good kit which will hopefully arrive quickly and we can help you tweak things once you can test.
    That is my opinion. What do you think?
    Jun 2010
    southeast
    I have no problem with starting over with this pool. I will have the new kit and we will try to keep the water clear. We will step up to a 5000 gallon or so pool no later than next spring & I see that I will be able to learn what I need to know here.
    Thank you so much for taking time to help me.
    You are very welcome, Mike. Let us know when you refill and get some good testing numbers. We'll help you get all your levels balanced. In this case, refilling and starting again are a good decision.
    Jun 2010
    British Columbia, Canada
    Cool Re: Small Pool, Cloudy Water
    Hi,
    I am also in the process of setting up a 1700+ gallon 12 x30 Intex pool for my kids.. It also has no skimmer. Once I fill the pool am I going to be at a disadvantage as far as maintaining the pool as a result of this. Have a 530 gal/hr pump and cartridge. Hopefully this does an adequate job????
    I am not really in favor of paying the $170 for the Taylor test kit up here in Canada. Only reason being, the kit is more than the whole set up. Can anyone recommend another way or test kit that may be cheaper and do close to the same thing as the Taylor... Maybe I am dreaming!
    I had no idea this whole pool thing was going to be such a hair puller!
    Cheers,
    Carrie
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Hi Carrie, in your other post there were some alternate kits mentioned, did you check on those? I wish there was something we could do to get you the good kit at the USA cost... How far from the boarder are you? Do you have any friends/family in the USA?
    The Intex pools are notorious for not having adequate filters/pumps, but since it's a pool that will only last a few years it's probably going to get you by... You'll just need to NEVER let it get fouled up as there will be no way for you to quickly clean it up with that setup. That's one of the main drivers for you getting a good test kit! You could easily end up spending a lot more than the kit cost trying to fix an issue if you get algae or something else.
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    May 2010
    a knee highstocking works as well as a skimmer sock just let it dry after use and brush the dirt off and re use next time
    Hi Carrie, please keep all the info regarding this problem within your other thread--when people post the same question in multiple places it makes it hard for the people trying to help, and makes it kind of tough for us to keep the forum organized.
    Thanks!!!
    Jan
    Jun 2010
    southeast
    Ok, this is where I am on this little pool. After the super dose of bleach the other day the pool was perfectly clear the next morning. What I do have a problem with to some degree is the what I assume is dead algae. Without a proper vacuum I think I am stuck with a little of the debris from the algae bloom. If I keep it stirred and the filter clean it gets maybe 3/4 of it but never all. Probably should have changed the water as Watermom suggested and may yet.
    The main reason I am in here tonight is for help with the Taylor 2006 kit. There is a link below to a copy of the instructions. In Step 1 there is a reference to using one of two amounts of water for the test. This confuses me. The next thing is in Step 4 in particular the line.... Multiply drops in Step 3 by drop equivalence (Step 1). I also have the same basic question about Step 7....Multiply drops in Step 6 by drop equivalence (Step 1). I think I understand the rest on the chlorine test. I haven't even ventured into the other tests yet.
    http://www.taylortechnologies.com/pr...er&Number=5138
    This is going along fairly well and would like to thank Watermom and the rest of the forum for helping me.
    Mike
  1. Water problems in small, small pool
    By MikeFromMesa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2013, 04:53 PM
  2. Filling a small pool with iron well water
    By newbiepool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 05:24 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Small, Shiny Specks in pool water?
    By wposton84 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-22-2011, 12:26 AM
