We really need to see a CC reading. That is an important reading because it kind of acts as an alert when there is something going on with your water even before you can see a problem. Repost with that reading.
6 oz. would take your cl level to around 3ppm which is ok for such a low cya pool. Are you ever going to 0 chlorine level during the day? If you do, you may have some CC which could account for the cloudy pool.
TA and pH look ok but just keep an eye on the pH and make sure it doesn't go any lower. If it does, you'll want to add a little Borax to bump it back up.
