Re: New to Forum could use a little help
For anyone looking to shock their well which does help reduce clear water iron (you know it is clear water iron when the water comes out of the tap clear but turns brown after a few minutes). Below is a nice instruction.
Hi JKoch;
You can't post links yet -- I modded your post in without the link, and then checked. Seems OK and UGA.edu security should be OK.
But, there is a MAJOR insecurity in Adobe Reader and PDF files that is not fixed. So here's my caution to ALL readers. Before you read ANY PDF file off the Internet (even from here!), turn OFF JavaScript in Acrobat reader
Open Acrobat, and go to Edit | Preferences | Javascript \ UNCHECK "Enable Acrobat Javascript" and that's it. At least till you update Acrobat. But Adobe's profit plan for Acrobat depends on 'features' that Javascript makes possible, so they re-enable it behind your back with every update.
Anyhow here's the link for the PDF from UGA.edu:
http://www.fcs.uga.edu/pubs/PDF/HACE-858-4.pdf
PoolDoc
