Thread: Pressure guage under pressure!
    NJ
    Default Pressure guage under pressure!
    This will be my 4th year with my pool and starting last year I noticed that my pressure guage would reach 15 psi within a day or so after backwashing. When I first got the pool, the pressure would stay at or below 10 psi for about a week or even two before it got to 15. Now, it seems that the pressure shoots to 10 right after backwashing and goes to 15 withing a few days. I've changed the pressure guage and it does the same. Any possible reasons for this? By the way, what is a "danger zone" level for the pressure guage? I was told by my installer to make sure it doesn't get to 20 psi.
    Thanks.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: Pressure guage under pressure!
    Is this a sand filter??? My sand filter has begun to do the same thing, and I'm wondering if I need to clean filter as I did not do so for winter maintenance.
    CaryB
    OK, I have NO idea why he says 20lbs is bad. Sand filter?
    Your pressure gauge isn't the problem. Either your filter is clogged or you have a restriction somewhere, or it's really too small for your pump. Have you changed pumps recently?
    A sand filter may have gummed-up sand, or broken laterals. DE filters may have hard crusting on the screens. Cartridges may be clogged beyond what hosing-off will clean.
    NJ
    Sorry for leaving out the fact that yes, it is a sand filter. I have not had any change in pumps and, as stated in my original post, everything worked just fine the first two years. Are there tests that I can have done to the system to see if there is a blockage somewhere? By the way, when I backwash, I normally fill the pool to the point where I can backwash for a good 15 minutes before the water level returns to normal.
    Thanks for any tips/suggestions.
  1. Pressure keeps going 30+
    By Reckoning in forum --cleanup--
    Last Post: 12-17-2012, 12:27 AM
  2. Low pressure
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 03-09-2010, 02:18 PM
  3. Remove pressure guage from filter?
    By [email protected] in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-21-2007, 08:45 PM
  4. Is Pressure guage important?
    By ePoolUser in forum Pool Equipment & Operations
    Last Post: 05-15-2007, 02:44 AM
  5. Low, next to NO pressure
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 09:02 PM
