Results 1 to 10 of 10
Thread: Testing with high TC
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    Default Re: Testing with high TC
    When testing high levels of chlorine with DPD, add the DPD1 and DPD2 in the empty test cell then add the sample water slowly - it should turn pink, then red then clear as more and more water is added. You can determine that way if you're in a 0 TC or high TC situation.
    For CYA there was an article by Woto in the JSPSI describing the interferences of CYA with high chlorine, as I recall he does mention to add a few drops of thiosulfate to the sample water. I'll have to find the article.
    And with the ProTeam borate titration, a high TC level bleaches out the indicator.
    Reseller of Taylor water-testing products for Canada
    Quote Originally Posted by giroup01 View Post
    Which is why I usually use the LaMotte Borate strips! The color change in the Proteam indicator is just plain hard to read, bleachout or not! If memory serves correctly it is bromphenol blue. I do use the Proteam titration kit when I need to make adjustments to the borate levels (perhaps once a year) but the strips are good to tell me I am in the 'sweet spot' of 30-50 ppm!
