Results 1 to 4 of 4
Thread: Stuff on bottom?
    May 2010
    322 Church St
    Default Stuff on bottom?
    Well, I'm still pretty new here and have been having a great time with the pool. I'm having a bit of a problem with "tiny" stuff that gathers on the bottom of the pool. I use the cheap water hose vacuum that came with the pool, but I think this stuff is just going throught the sock (it's catching the big stuff, but I can see a cloud blow right through the sock at times.) What's the best way to deal with this "water dust"?
    Default Re: Stuff on bottom?
    Can you give us a bit more info please?
    -- Complete current water testing results taken with a drops-based kit (not test strips)
    -- type and size of pool (volume)
    -- type of filter
    -- size of pump
    Also explain more about your vac. system. It has a "sock" at the end of the hose?
    Have you tried putting skimmer socks in the skimmer basket to help catch the finer stuff?
    May 2010
    322 Church St
    Angry Re: Stuff on bottom?
    Well, after doing some more research (and actually reading through some post) I think I'm dealing with that yellow/mustard algea.
    I've got an AG pool 18'x4'. I've just got the intex pump that came with it. I'm also using a SWG that I got. The vac that I'm using is the one that you hook up to a water hose and it uses a venturi idea to push things into a little filter bag.
    I'm going to blast it with some bleach when I get home and start the pump running 24/7. Wish me luck!
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. Sandpaper like stuff on bottom of pool
    By motomomof2 in forum Dealing with Algae & Slime
    Last Post: 05-29-2013, 05:51 PM
  3. Stuff on Bottom of Clear Pool... Brown Algae??
    By Tabisme in forum Dealing with Algae & Slime
    Last Post: 07-26-2011, 05:30 PM
  4. Cleaning stuff off bottom of pool
    By cygnusecks in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-11-2006, 05:11 PM
