Have you had the salt level verified? Usually when the water temperature falls around 65 degrees or lower, the SC-48 cell will give you this warning due to the combination of the water temp and low salt levels. My guess is that the salt is low and needs to be calibrated, in conjunction with the cooler water temps and there's a chance that the cell may be wearing out too.
Do the two outer blades in the cell appear to be shorter than the blades between them?
IF your salt level is low, calibrate the salt display to match your test results, then add enough salt to get your level up to 3500 - 4000 ppm. This will compensate for the reduced conductivity in the water from cold water temps, and/or low salt levels.
Keep up posted.
