Thread: Broken Pressure Gauge
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Default Broken Pressure Gauge
    I've got a Hayward EC-65 DE filter that has a broken pressure gauge. I bought a new gauge from the pool store but its got a 1/4" threaded copper connector and it looks like the old owner somehow rigged the current pressure gauge so its not standard.
    The front of the filter has a pvc elbow attached to it so that the current gauge is somehow screwed into the top of a piece of pvc attached to the elbow. I tried unscrewing the gauge but I think it might be glued and I will have to cut the pvc and attach the new gauge.
    Do they make a 1.5" pvc "nipple" that will allow a pressure gauge to be screwed in? I'm not really sure what im supposed to do here.
    Smile Re: Broken Pressure Gauge
    Hey Fog, been a while - is all else good with you?
    Your EC 65 should have a 'tap' in it to accept the pressure gauge. If it's been abandoned and covered over, there are tees with adapters available to accept the gauge - or you can just do as the previous owners did and drill a hole into one of the pipes, tap it to accept the threads and be good.
    More info available if you need it
    Honesdale PA
    Default Re: Broken Pressure Gauge
    If you need brass adapters to go from almost anything to anything check Home Depot or Lowes. Makes it easy to adapt to various threads and sizes.
    I let it go last year after I couldnt find a 1/4" to 1.5" adapter but this year i may need to move forward and find a solution to this.
    So waste, you are recommending cutting the old pipe off if I cant "unscrew" the gauge and putting a new pipe in place that I can "tap" into.
    I'm a little worried about tapping into a pipe with such a high pressure area and I dont want the gauge blowing off one day. Any more tips on how to get this done?
    The old owner glued a 1.5" pvc elbow into the old EC65 gauge "hole" and extended the pvc to run sort of parallel to the filter. I was thinking of cutting the pvc right below the existing gauge and installing a new gauge at this location. Any additional tips are much appreciated.
    Apr 2011
    virginia
    you don't need to worry about high pressure- your pressure shouldn't be over 20-30 psi, and those gauges are designed for pressures up to 125 or better...
    Old steam pipes were put together with threads, and had 50 psi at 250-300 degrees!
    if the previous owner glued the pvc elbow over the existing port, I would make sure to leave enough when you cut it to attach another piece- but cutting and fitting in the adapter is a good plan
    Ok so if i cut and attach a fresh piece of pvc to this "arm". How do I get the 1/4" threaded opening for the gauge? Ive been to lowes and home depot and I cant see anything that takes a 1.5" pvc and converts it to a 1/4" threaded opening.
    Apr 2011
    virginia
    you may have to step down a couple times- adapt from 1.5 to 1 to 1/2 to 1/4...
  1. Pressure gauge bad?
    By iBrew in forum Pool Equipment & Operations
    Last Post: 05-05-2012, 08:07 AM
  2. Pressure gauge failure?
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 06-01-2011, 10:33 AM
  3. SP710 pressure gauge
    By cantileveredge in forum Pool Equipment & Operations
    Last Post: 09-04-2007, 09:17 PM
  4. Replacing Hayward EC-65 pressure gauge
    By ChuckD in forum In-Ground Pool Construction and Repair
    Last Post: 05-16-2007, 02:29 AM
  5. changing out pressure gauge
    By bbluvbasket in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 12:24 PM
