Results 1 to 10 of 44
Thread: I'm in big trouble - I turned water green
    Default Re: I'm in big trouble - I turned water green
    Don't panic. Take a look at the following thread. This is pretty much the same situation that you are in. Then, come back if you have any questions. We will need current water testing readings taken with a drops-based kit (no test strips.) Do NOT empty your pool.
    http://www.poolforum.com/pf2/showthr...3310#post63310
    joecus is offline Lifetime Member Thread Analyst joecus 0
    Jun 2010
    nyc
    Ok, I read the post but I'm not sure what part of that is the same as me. Since the water is bright green, how am I going to take a reading? Do you know what caused the reaction? Why would the idiot at the store tell me to buy sodium bromide if this was going to happen? Please tell me step by step what I should do, I'm at a loss. This is not my first experience with a pool. Nothing like this has ever happened to me. So, what caused it? What will fix it?
    Hi Joe;
    I've never seen a bright green reaction, either.
    Yellow, yes. Orange, yes. Cloudy, yes. Brown and clear, yes. Brown and cloudy, yes. Even purple, yes. (Boy, that's a wild story I should tell sometime. BIG boo-boo!)
    Bright green? nope.
    Odds are it doesn't matter. You've got a mess, but it will probably eventually clear up with chlorine bleach and sunshine.
    I would cautiously add bleach -- the peroxide will keep destroying it for awhile -- till you can hold a residual overnight. Once you get there, you'll have to start shocking the heck out of it at night, to get rid of the bromide / bromine.
    By the way, if you can reach any of the spots, scratch one with your fingernail. Then, spread the goo from under your fingernail onto a white card. If it's black algae, the smear will be dark green. No smear, or nothing under your fingernail, it's not black algae.
    Oh, and if you can dig that shock container out of the trash, and find out exactly what was in it, that would be good to know and post.
    Good luck,
    Ben
    "PoolDoc"
    Joe -- what I meant was that the poster in the other thread had also added sodium bromide. Lots of bleach may be needed. PoolDoc has jumped in on this one, so you're in good hands. Good luck.
    Jun 2010
    nyc
    Thanks Ben - I don't have the exact mixture of shock in front of me but it's the shock I've always used. The one pound bag, purchased at Costco. I'll get the name in the morning. I thought about it and wanted to add this. Did you ever use the test kit where you add 5 drops of oto to water sample to get a chlorine level? If you had a lot of chlorine in the sample, the water would turn bright yellow, if you had a real lot it would turn bright yellow with one drop. This is what happened to the entire pool. The color is bright yellow/greenish so maybe saying its bright green is not totally accurate. Bright yellow/greenish would be more accurate. Instant chemical reaction.
    Was there an odor?
    What was the pH at that time?
    Last edited by PoolDoc; 06-16-2010 at 07:49 PM. Reason: remove distracting comment.
    Jun 2010
    nyc
    I woke up this morning and pool back to being clear, wow. I turned the filter on and the residual water that was in the tank came out bright green/yellow. So, something happened, overnight, that caused another reaction. I checked the chlorine, zero reading (I'm using the kit with the drops). The PH was low. Any suggestions? Thanks.
  1. Pool water turned green after shocking. How to clear it??
    By aces3 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-29-2013, 09:56 AM
  2. Baking soda turned my pool green
    By BigStein in forum Dealing with Alkalinity and Calcium
    Last Post: 08-12-2007, 01:10 PM
  3. Water turned green after adding shock treatment
    By NowhereMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2006, 12:25 PM
  4. shocked turned my pool green.. help!!
    By lulamink in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-31-2006, 10:45 PM
