Results 1 to 10 of 17
Thread: Who has an Intex Ultra Frame 24' pool?
    Jun 2010
    Default Re: Who has an Intex Ultra Frame 24' pool?
    Thanks a bunch. I can use 12" by 12" pads for sure.
    How did you know what the diameter of the circle was where the pads land?
    It says its 24' pool but that is probably not where the legs are.
    Thank you
    May 2010
    Kilgore, Texas
    The way we done it was to level off a 24' dia spot, then put the pool together, then level all the legs, this is where the laser level will come in handy, your going to need a couple of guys to help you put it together, the last piece of top rail is a #$%@$#$ to get in, then you can put a little water in, maybe 2" then go back and level the legs. its a pain in you know where, but that is the best way I could figure it out, like I said the legs move they slid out as you add water, and when everyone i the pool they still move a little.
    Jun 2010
    Thanks a bunch. I was thinking about laying out the top ring and marking where each pole would go based where the pole attaches to the top ring. Would you say the legs push out from verticle at the bottom or do they push in from verticle once water is in the pool?
    Thanks a bunch.
    Jun 2010
    Northcentral MS
    Quote Originally Posted by jkoch View Post
    Thanks a bunch.
    They will push out generally since the top ring is your "fixed" point. I helped the mother-in-law set up one of these Wally 24" Intex pools. She too is on year 2 with a salt water system as the only upgrade from standard.
    The pool top ring is a T-total B$%$# to put together as moose said above, so drink lots of beer before installing. We leveled the pool area using the string method also and were within about an 1". No pads were used because the ground is hard Mississippi red clay underneath. As moose said, the pool will move and shift as water is added, so plan accordingly.
    I can measure the top ring diameter for you tonight after work if you would like? It will be late tonight though.
    Michael
    Jun 2010
    Thanks a bunch. Sorry for the later reply, work getting in the way.
    What I really need is not the top diameter measurement but the diameter measurement at the bottom where the feet are. If you could get me the diameter at the leg bottoms that would be perfect. I really appreciate the help.
    May 2010
    I have this pool. 54" I had the same experience with the poles leaning. Mine is not on footings as I had a level spot in the yard when I started, so I'm not dealing with unpacked sand. I used excessive amounts of roundup, spread the square blue tarp that came with it, and called it good. So far, the tarp is keeping the legs from sinking. But some arent perfectly straight. Some things to keep in mind...
    1. Be very aware of rotation and where you REALLY want ur pump equipment. I thought I wanted it "here" and now I wish it was "there".
    2. Leveling: water dont lie. The squares on the liner should be level. Meaning if you count them down from the grey part at the top, you should be able to use that count all the way around the pool as it starts to get about a foot or so of water. Mine is no more than 1 square off from one side to the other and I'm happy. At the very least, the water will be level. So you can use a tape from the water level to the top rail to see how ur doing. If it's more than and inch and a half off from one side to the other, i'd stop and start over on your leveling before you get all the way full and decide you dont like it.
    3. Have a bullet level handy. I didnt. This is why my legs arent perfect. I was eyeballing it. At first you cannot level the legs. The rope at the bottom will screw you in trying. (u'll see y) But as the pool fills, keep going round and round the pool with the level, and keep releveling the legs (both ways) until the point you cant lift them anymore. It'll be about 3ft full when you can no longer lift them. At this point, it is where it is. It's also not very stable yet. Dont worry, that last foot of water makes the pool ROCK SOLID.
    4. I went around shaking the top rail as it filled and got heavier. If you do this you can hear the vinyl pop as it starts to stretch and "seat" where it'll wanna be forever.
    5. If you have trees, even NEAR the pool, that small Intex filter may annoy you cleaning it. I had to go to a sand filter before I was really happy, but I wouldnt trade my partial afternoon shade for anything.
    6. This pool is WAY TOUGHER than I had ever imagined. I am SO GLAD I got the Ultra. However, the ladder leaves A LOT to be desired. And as tough as it looks, the top rails are not indestructable. Some idiot, (idk who, cuz they wont admit it) was jumping from the side and bent one down a little in the middle. But the mere fact that someone 200# plus can stand on the rails and feel safe is a testament to how tough this pool really is.
    I suppose at the start of next season, I'll drain it, and fix my first little mistakes at setup. But luckily, I had nothing that I couldnt live with for the first season to make me drain it immediately. I'll probably take it down this winter, and rebuild it next year, and it'll stay there for good that time. Hope this helps.
    May 2010
    Kilgore, Texas
    JKoch thats almost impossible to measure, the only way your going to be able to do this is level up a 26' dia spot. then put the pool together then start filling it then you can work on the legs. you can put a 1' of water in it and still be able to lift a leg up you had a great ideal with putting the top frame together then marking the legs but that is as close as you can get it. I could measure mine but that does not mean your's will be the same. and plus these legs move a little the only thing you can do is make sure they are level side to side. they are going to lean in or out, there's nothing you can do about that,
    My square's on the inside are not level, I have a full square on one side where it meets the Tan part and on the other side I only have a half square. so I would use a tape measure to check unless your sure. the water line to the top rail mesurment is the only true way to tell. like satguy said the water level will not lie,
    Everything I have heard is you get about 2-3 years life out of these pools. so don't worry alot about the tiny details, get it as level as you can, fill her up and enjoy.
    I knew when I got this pool is was a temp thing, me and the wife were not sure if we wanted the up-keep of a swimming pool, or how much we would use it, so we didn't want to dump alot of money in a above ground pool untill we were sure, but we love it and with the help of these guys and Girls (didn't want to leave out WaterMom) on here, pool up-keep is as easy as it gets, So thanks to all next year Me and the Wife will install a Hardside above ground pool.
    I also did as Satguy did and put a sand filter on mine
    Satguy are you sure about the 54" mine is a 52" I didn't think they were making a 54
