Yup. Has a standard fitting like a skimmer or brush. It wouldn't be worth it without it, but that's a good question.Originally Posted by kevincad
I just got one of these this year (new pool), I was on the fence until I read CarlD's post in the "old" forums. I bought the CG model, supposedly 1/3 more suction and charges in 2 hours (instead of 8). So far, it has been wonderful. We don't currently have any type of robot (I have an Aquabot Pool Rover Plus on order, didn't really want a "scrubbing" unit, this one just uses water pressure to clean). The CG model includes the fine filter bag which traps silt and fine dirt really well.
The thing sounds like a toy until you put it into the water. Then you can just feel a little vibration through the pole. We have run ours about 30 to 40 minutes at a time with no problem. You do need to clean out the filter bag more often than WaterTech says, but we use a small bucket and it is no problem. We used it on opening, took several days to really clean up the silt that had fallen through our mesh winter cover, but now we use it once a day before swimming. We use the little roller wheels instead of the brushes, supposedly (according to the Watertech website) this provides more suction and is safe for vinyl.
My wife loves it, it is SOOOOO much easier to use than the regular vacuum setup. If it had a larger coverage and filter bag I might even consider not getting an automatic cleaner!
How often do you have to clean out the filter bag, and how big is your pool?Originally Posted by tphaggerty
I do not have a vacuum right now, and was thinking about buying one of these instead of an aqua bug. What does every one think?
You can even use the original PB as your main vac. It's easier and faster to use than a hose vac, too. Spend the $25 on the finer filter bag, it's well worth it.
You should clean the bag after every use. First dump out the junk you can, then just take a bucket of water and rinse it. Repeat once on the rinse in a fresh bucket and you're done!
As CarlD said on cleaning. Our pool is a 20x40 IG and I normally have to empty clean the fine mesh bag twice when cleaning. But, we are still building around the pool so we have TONs of millipedes and lots of dirt still getting in plus lots of pollen and such.
But it takes, at most, 2 minutes to remove/clean/reinstall the bag and go.
I didn't realize the fine bag was $25. At that price, I think the extra 50 I spent on the CG model was worth it (it can with the fine mesh bag and the regular bag, plus charges in 2 hours instead of 8 and is supposed to have 30% more power, but who knows on that part).
I picked up 30-50% more power just by replacing the battery/motor pack. At $79., I wish I had sent it back under warranty.If only I knew then what I know now...
Still, that and $25 for the filter was STILL cheaper than replacing it with a new one, and now it's like new again--better, actually, because I don't think the orig pack EVER ran like this one.
I've just ordered the Dolphin with the remote control. I think yours does not have this, but maybe you can give an opinion anyway.
Do you think the Dophin with the remote would be good for picking up bits of leaf etc as effectively as the PoolBuster on a pole ??
I don't know. I don't have any dead algae, and haven't had much in years.
bbb-on the Blue Haven site it says the Catfish is for above ground pools and the Buster is for inground pools. Don't know what the difference is between them or why the Catfish couldn't be used on an inground pool.
