Re: Help with getting levels right please!
We are back and do not have a green pool! We have skimmed and vac pool, tested water, changed filter and now the pump is running. I did order the test kit Watermom suggested but it is not here yet, so I used my hth tester and here are my results:
PH 7.5
CL/BR 5/10
TA 190
TH 300
I know my TA is alittle high. Right now the water looks alittle cloudy but might just need the pump to run to clear that up. I do have some PH minus, which is what they say to use to bring it down, but will that bring my ph down too low?
I can not test my CYA yet, because I am out of testing stuff for that with my present kit. Once I get the Taylor kit I will test it.
