Thread: Hayward Skimmer Flaper Broke
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default Hayward Skimmer Flaper Broke
    Pool installed 1988 -inground-vinyl -with Hayward skimmer. Yesterday found have the skimmer flaper inside the basket.It has been cracked for a few years and have made attempts to glue. Finally gave out. So some questions:
    Can I just replace the flapper and how difficult is this?
    What are disadvantages of operating without the flapper?
    Other recommendations?
    Honesdale PA
    Default Re: Hayward Skimmer Flaper Broke
    That flapper is a weir and just keeps debris caught by the skimmer from going back in the pool when the pump turns off. May also create a little better skimming action. Have you tried PVC cement? Yellow can, multi-purpose. Depending on where it broke it may not be fixable. I don't know specifically but it would seem like an easily breakable piece and should be able to be replaced easily, if you can find one.
    I don't have a weir on my skimmer. Mine broke years ago and never was able to find a replacement for it that would fit it. I just try and remember to empty the skimmer basket before turning off the pump so the stuff doesn't just float back out into the pool.
