Results 1 to 10 of 12
Thread: Need help identifing the connector on Smartpool Nitro cord, any electrical geeks?
    Connecticut.
    Default Re: Need help identifing the connector on Smartpool Nitro cord, any electrical geeks?
    It looks like a "pin and sleeve" connector. But, everywhere I look they are NOT CHEAP. Ebay had one for 75.00 but Im not sure thats the correct one for your application.
    Hate to say it but the best deal might just be to order it from the company.
    Hurst, Texas, USA.
    Looks like Chris is right about those prices, WOW! Here is a link that may help, though I am guessing you've found this site: http://store.jbn-duraline.com/durali...tors_4wire.htm
    Here's another possible site: http://www.electronicplus.com/conten...=wc&subcat=wma
    http://www.laddinc.com/our-products/...ayout=category
    http://www.connectdsc.com/search_res...?waterproof=on
    http://www.theelectricalresource.com/category/waterproof-connectors.html
    Looks like they are called multi-pin waterproof / marine connectors.
    23,000 gal. Vinyl IG. 40,000 gal Hayward Aquarite SWCG. 48 SqFt Pentair Triton D.E. Filter.
    Connecticut.
    Yep, and dont forget www.mcmaster.com for basically any thing on the planet!
    They have them too, but again really expensive for some reason. Not counting the work that would probably go into replacing the female portion (the part thats in the actual power supply)
    Jun 2010
    Thanks everyone for the suggestions. I have look through way to many catalogs now trying to find a match. Since there are no markings on the plug or socket I can only guess that this a "made in china" knock-off and not to spec connector. Most of the connectors in the catalogs look to be of higher quality. I even stopped at a local professional electrical supply store and they could not identify it.
    I also sent email with the photos to Mouser sales department and they call me back stating that they have forwarded it on to the tech support. So I hope to hear back from them in the next couple of days.
    If a replacement plug can not but be found, I am can going to just solder the pins back on the cable and silicon them into place. Then to untwist the cable, I will turn the transformer instead of disconnection the cable.
    Honesdale PA
    Another thought is to do as you suggest, siliconing a wire right to the unit. You may then find a cheaper waterproof connector and put it in-line so you can still disconnect. You would have a short pigtail on the unit.
    Try Lashen Electronics' web site. It's www_dot_lashenelectronics_dot_com. They MAY have what you need. It looks a lot like a microphone barrel connector and since these cleaners are low voltage, that may do the job.
    Jun 2010
    Upstate NY. home of the cold ingrounds
    blueenergy how many terminals is used in the connector. i only see 3 being used in the first picture.. if it is only using 3, Pos, Neg, ground try your local radio shack.. they carry alot of amature radio connectors. you can waterproof many of them yourself.
    3rd year - homeBuilt! by ME! 11500 Gal. Vinyl inground
    haward S180T with a 1hp Super Pump
