Results 1 to 10 of 16
Thread: Robotic Vacs for IG Pool- Good and Bad Experiences Please
    May 2010
    Central NJ
    Default Re: Robotic Vacs for IG Pool- Good and Bad Experiences Please
    As I said in a different thread, also with TomC loving his. Mine is gathering spider webs. I manually vac. It is the difference between "picked up" and "clean" to me. The Aquabot does a decent job although it always misses some stuff, but it will get stuck on the ladder and sometimes on the main drain. I wouldn't run it if wasn't around paying at least a little attention to it. I guess, to me, there is something to starting the weekends in the summer with that sparkling, perfect, squeaky clean feeling liner (and walls). I tend a 33,000 gallon IG vinyl rectangle. I'm kind of in the woods too if that matters. I don't generally need to brush my pool after the opening fun, I just thoroughly vac 1X per week weather permitting. It takes about an hour and a half from start to finish.
    Good luck, i hope you love it and it works out great for you!
    PL
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    My BD gets stuck on the ladder as well--or it did. I can remove my ladder in less than 30 seconds so I do so when cleaning--I also pull out the floating thermometer.
    I tried once to develop a cage that would block off the ladder so the cord couldn't get under but was unable to. Strangely, the Dolphin NEVER had a problem with the ladder--it's only real advantage.
    I had a Dolphin Dynamic for about three weeks - it was terrible. Did not clean that well, and then just started going back and forth in a 10' straight line without leaving that area. Fortunately I bought it online from Costco, so I just took it back to the store and got my money back. That was something like three years ago. I got a Blue Pearl to replace it, and it works great. It has run with no issues until a few weeks ago when the little internal drive belts that take power from the motor to the traction belts wore out. Bought new ones online from ebay for $20 and now she is back in business working great.
    Quote Originally Posted by PBLsQuad450 View Post
    PL
    I've now had my Aquabot Supreme for about 1 week and have run it 4 or 5 times for 2-3 hours/run in my 18x36 free form vinyl pool. I am highly impressed with its performance. Within 2 hours or so, it has cleaned the entire pool. It does NOT get stuck behind the ladder. It does hit the ladder, but it reverses itself after several seconds. It climbs the walls without problem right up to the water line and also partially climbs and cleans my walkin steps. The filter bag is loaded with small debris that I could not see. My water is sparkling clear and as long as the Aquabot lasts a long time, I will be VERY HAPPY with this purchase.
    Ultimately, all of them come from the same family. I don't know who was first, but the story I heard was it was invented by an Israeli family and the various members had a falling out and each started their own version--which is why the Aquabot, Blue Diamond and Dolphin are all basically the same design--two or three motors (depending on whether the treads are single or doubled), angling handle, center motor vacuums up junk and sucks the thing down so it sticks to the wall.
    I figured out that since there aren't any sensors in these things, they must sense the change in current draw when they hit an obstacle and they can even analyze that change to determine whether to reverse or try to climb the wall. Kind of like when a power saw is pushed TOO hard and the lights dim. Since they were all family there must have been some agreement on patent sharing too.
    Jun 2010
    Just south of Atlanta, GA
    This web site has some good info on robots, and also some hints for repairing the Diagnostic Dolphin: http://www.i-love-my-aquabot-automat...com/index.html
    I can give you a users' report on the Dolphin. We bought one about 5 or 6 years ago. For some time all was well; it climbed the walls, it vacuumed, it dusted, it polished. However, about 2 years after we bought it the strain relief on the power supply gave way. I opened the power supply (the horror!) and determined that replacing the plastic fitting wouldn't be beyond my abilities, if I had the fitting. Maytronics, the Dolphin's momma, refused to sell me the fitting, told me I should send the ENTIRE unit to them, at my expense, of course. They said they'd update software, etc.
    About $60 shipping each way, my dime both ways, plus about $150 for Maytronics' expertise the Dolphin returned with the strain relief fixed, plus a float added to the supply cord about 2 feet from the robot. This, I was told, was to insure that Dolph wouldn't trip over the cord. Problem is, now even with the floats on the handle removed Dolph's wall climbing is but a shadow of its former self.
    Early this summer I noticed that the flexible clear plastic cover over the power supply switch was deteriorating. An extensive net search located one, with a $25 minimum order for a $3 part. I called the local Diagnostic distributor in the Atlanta area, and was told that the design of the cover had been changed, so shipping the power supply might be necessary. After a little whining and pouting on my part, they located a cover (on someone's desk?) and sent it to me gratis.
    At one point Dolph had thrown a tread. I used the above site and took off the side plates and removed .... a plastic shard from one of those really flimsy little pots that bedding plants come in. The plastic was barely thicker than 30 pound paper! Nasty job undoing Dolph, I left some blood behind, and I've done car clutch jobs, etc.
    Long story short, I doubt we'd buy another Dolphin. YMMV, of course.
    I loved my Dolphin until it failed in its 3rd year--and I had to deal with the nightmare of Maytronics.
    When my newest Blue Diamond failed, I dropped it off at the repair depot in Cedar Grove, NJ. Two days later it was on my doorstep, fixed perfectly, at NO cost to me. Their service blows Dolphin's out of the water and into the Gobi Desert!
    Quote Originally Posted by myLABSpool View Post
    Just a quick and final update (unless something changes my opinion). I've now had my Aquabot Supreme for nearly a month and we could not be happier. We run it every few days as needed and our water has never been clearer nor pool walls and bottom cleaner. We have teenagers, their friends, a black lab and golden retriever that use the pool regularly. The amount of dog hair, dirt and grass clippings picked up by the vac amazes me. I am absolutely amazed at how much stuff I find in the filter bag each time it runs, even when the bottom only looks slightly dirty.
    The Aquabot usually covers our entire 18x36 24K gal free form pool including walls up to the waterline in about 2 hours, although I usually set the timer for 3 or 4 hours to take advantage of the water filtration capability and help my filter. In fact, I have not backwashed since I got my Aquabot.
    I am very, very fussy about ultra crystal clear water and I know the Aquabot has been a big help in getting me there.
    So if you are in the market for a robotic vac and have $1000 budget, I would highly recommend the Aquabot Supreme.
