Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 44 of 44
Thread: Metal in pool
  1. #41
    Default Re: Metal in pool
    It should.
    AG pool filters tend to be undersized, and the pumps oversized. Your filter will perform better if you can throttle the flow back some.
    Ben
    "PoolDoc"
  2. #42
    Jun 2010
    i don't know what throttle the flow means, but wish me luck.
  3. #43
    Jun 2010
    I just wanted to thank you all for your help. If it wasn't for all of the support and knowlege from this forum I would have never had a clear pool. It took a while and alot of vacuuming, but I am finally able to swim in a clear pool. I am even able to shock w/o dealing with brown water. I love the BBB method, and all of your other tips and tricks. This forum is amazing. Keep up the good work.
    Thanks again,
    Kristy
  4. #44
    Thanks for the update!! We always like to hear about it when you finally reach the end of that long road and find out that you CAN have a clean, clear pool.
    Happy Swimming!!
  1. Drain12 ft. Metal Frame Pool
    By TheKs in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2012, 07:57 AM
  2. Texas Plaster Pool Metal Stains
    By Captain Ron in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-17-2012, 06:07 PM
  3. looking for info on getting the metal out of our pool
    By brennac in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2012, 11:00 PM
  4. Metal in the water (Fiberglass 35K pool)
    By blk133 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-19-2006, 02:36 AM
  5. Intex Metal Frame Pool
    By SBaker in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2006, 11:48 AM
