Results 1 to 10 of 44
Thread: Metal in pool
    Default Re: Metal in pool
    It's always going to be a game to keep the chems right. The metal sequestrants hold the iron in suspension in the water, but they don't actually remove them. There is a thread started by a new user, labdi01 where she talks about some sort of filter she made that actually removed the iron from her water. It apparently worked for her, but I don't have enough experience with it to know whether to recommend it or not. You can read through it at http://www.poolforum.com/pf2/showthread.php?t=9706 and it might give you some insight. Also, read through Pooldoc's post (#22) at this thread http://www.poolforum.com/pf2/showthr...?t=9660&page=3 and see if it helps.
    Janet,
    I read the last post you mentioned--very good. It answered some of my questions. Apparently, sequestered metals will filter out. That is good news. I still don't understand why the metal out drops the ph and eats up chlorine. Maybe someone can help with that one.
    Thanks,
    Doris
    I am still having problems with staining. This is what I have been doing to correct the problem.
    I lowered my ph to 7.2, allowed the chlorine to drop to .5, and then poured in the specified dose of metal out. The stains dissappeared almost immediately. For two days I ran the filter and backwashed each day. Then I allowed the chlorine level from the salt generator to rise to 1.5. and the ph to 7.4. Within hours, the stains came back. I lowered the ph and chlorine again, and the stains disappeared again. I am now running the pool and backwashing again. How long will this process take before the stains stay away? My pool numbers are good, except for the alkalinity which is 135. I am trying to get that down through lowering the ph and aeration.
    Thanks for helping me.
    Dorie
    Quote Originally Posted by doriec View Post
    Janet,
    Thanks,
    Doris
    No, sequestered metals do not filter out. They are dissolved in the water and in an ionic form. Being sequestered means that they are not chemically reactive so they won't be oxidized and either color the water, deposit as stain, or precipitate out. Remember, the definition of sequester is to 'set apart' or 'put into seclusion'. Metals that have PRECIPITATED out of solution are filterable but they usually just redeposit on the pool as stain again.
    If you are referring to my post about chitosan, remember I said that I do not know how effective it is, just that it has been documented that it can combine with metal ions and then filter them out. I do not believe it is a very effective process or someone would have already marketed it as a metal remover.
    mbar's Avatar
    Ashland, PA
    When I am dealing with staining I never lower the chlorine when putting in a sequestering agent. One of the reasons the stains are disappearing is because the chlorine level is so low You have to get the pool to a level where you can maintain a sanitized pool and keep the metals sequestered. You just don't have enough sequestering agent in the water. The problem is that chlorine eats the sequestering agent, which makes the chlorine levels go low, which can lead to algae, which leads to needing to shock, which leads to more stains That is one of the reasons that I don't let the chlorine drop to add the stain treat. You can add some algaecide, which will help when the chlorine does go down. Here is what I would do, Get your chlorine where you want it by slowly adding it - keeping the ph low. Add more sequestering agent, if you see the stain start to come back, add more agent. Keep checking the chlorine and add it slowly to keep it at the level you need for your cya. It can take a while to get it right, but once you do, you just need to add the maintenance dose of the sequestering agent on a weekly basis. Remember you want the water sanitized first - that is the most important, this way you can swim - you can swim with stains, but not with water that has aglae
    Waterbear is right, you can't really filter out the metals, the only thing you can do is to keep them sequestered, or get them to stain on the filter, as PoolDoc explains in his post. Hope this helps, and feel free to ask any other questions you may have.
    Northeast PA
    Jun 2010
    I don't mean to barge in, but what they are telling you is correct. if your levels go out of wack. you will be back to square 1. I was having this issue since may. Tried metal out, but what my pool store wasn't telling me was to keep my levels balanced. I did find a product to clear my brown water since i have a small cartridge filter with my 5,000gal intex pool that doesn't do much. It's called pool stain treat. it's a sequestrant and chelator. Don't ask me what that means, but after 2 days of using this my water cleared,and the cartridge filter actually caught all the brown(washed it out 4 times). I bought this product on my own as a last resort before I took down the pool. Called the company that makes it(united chemical corp.) And just like the above posts the company told me that even with this, if my levels are off, bam, back to brown water. They said for this chemical to work you levels have to be balanced. This site is the best one that I have found out there. Thank you and keep up the good work.
    Pool stain treat is just oxalic acid. It works exactly the same as ascorbic acid but is more toxic. (Citric acid also works the same.) You are just lucky the stain reformed in your filter and not in the pool. A sequestrant is still needed.
    United chemical sell a lot of different products and makes a lot of claims for them. When you realize that the majority of their products are just soduim bromide (Pool stain Treat and the stain spotting bags being an exception since they are oxalic acid) and you look at the nonsense they call the Hamilton Index that they used to promote (and still do with their water balance recommendations) then you have to look at their claims for the products with a grain of salt.
    I am not saying these products do not work, in fact they do (some better than others). It's just the marketing hype does not quite agree with the reality of what is really happening.
    Jun 2010
    so even though this product(oxalic acid) states that it is a sequestrant, it is not? i know nothing about pool lingo. The only thing i do know is that i used 32 oz of metal treat(tricurboxylic acid/phophonbutane) , and also 32 oz of metal out(not sure what's in this). With both of these i've had no luck. since i used the oxalic acid product do i still have to add more of a metal out product?
    since i've added the oxilic acid my #'s are:
    TH:100 (this never changed since beginning)
    FC: 0
    pH:7.2
    TA: 240(highest strip goes) can't seem to get down
    CYA: 30 -can't get this up. used 4lbs of stabilizer and cond. last week.
    5,000 gal pool
