Results 1 to 10 of 44
Thread: Metal in pool
    Jun 2010
    Default Re: Metal in pool
    hello again. i hate to bother you but since i have added the pool stain treat, until yesterday, my water has been clear. My chlorine level has not been showing on my test kit. bought a different kind and it was showing FC at 1. I was using 3" chlorine tab in floater. I was happy with that since my water was clear. My husband decided to listen to someone at work about if our chlorine was low we could have bacteria and all get sick. Without me knowing he added shock, then the next day chlorine granules to our pool. I have no clue how much. Needless to say, brown water again. I took my water to get tested since the colors that showed on my strips didn't match some of the colors on the container.
    pH 8
    FC 5.1
    TC 5.1
    Alk 140
    CYA 60
    Copper 0.13
    Iron 0.17(was 0.9 last time got it tested)
    Hardness 140
    Phosphate 300
    My question is that if my Iron level is 0.17 would that be the cause of my brown water or something else? My water is the darkest it has ever been, but i'm assuming that's b/c my chlorine level and pH is the highest it's ever been, right? Also, I did add calcium. The pool store told me that i should add it b/c they told me that over time being low my liner could become brittle. They told me to add 2Lbs for my 5000gals. I don't even think I added a pound b/c i wanted to go slow with that. Could that have added to the brown, also? I was doing so good. I kept my pH at 7.2 and chlorine at 1 with that floater. I have never added any more cya to my water since i setup my pool. Why did my pH rise to 8, and cya go up to 60 since he added the shock and chlorine? The only cya i added was when i opened my pool a month ago, and my shock or chlorine does not contain anything like that.I did add the pool stain treat again last night. I guess since my water is real dark it will take longer to clear? Also, I know this could bring my pH down. If it doesn't bring it back close to 7.2 how long should I wait before I buy something to bring it down?
    mbar's Avatar
    Ashland, PA
    What kind of pucks are you using? If they are tri-chlor then they contain cya and will bring your cya up pretty fast. With a cya of 60 you want your chlorine to be at 5ppm for your low number, so your chlorine level is good. The high ph will cause the metals to fall out of solution. Just taking your ph down should help. What I don't understand is if he put in a lot of chlorine, then it should have come in at higher than 5.1. Maybe you were fighting the beginning of an algae break, but you don't measure any combined chlorine, so I don't know if he put in all that much. I don't understand how your ph is so high unless the pucks you are using contain calcium instead of cya. In order to have a puck the chlorine has to have something to bind on to, so it is either cyanuric acid (cya) or calcium (calhypo). The only way to get chlorine without these is plain bleach which only has salt in it. If there is no chlorine in the water, then you will not have any stains, because there will be nothing to make the metals fall out of solution, but I am afraid your husband is right - you need chlorine at a level to get rid of bacteria (which you can have with clear water). You don't even see an algae break out until there is enough to make the water cloudy. You will find the balance with your pool - you may just need some more sequestering agent to hold the metals in suspension. Sequestering agents should lower the ph, if not then add some acid. You are better off to keep your ph on the low side. Chlorine levels can be kept on the low side, but for a cya of 60 you need a minimum of 5. Your shock level would be 20 - if you keep up with the water you should not have to shock. It is a matter of keeping the right amount of sequestering agent in the water for the levels of chlorine you need. Feel free to ask any questions, I know it's frustrating, but it is doable (is that a word?).
    Northeast PA
    The fact that the chlorine and pH were raised is probably what caused the iron to precipitate and give you brown water. We know how the chlorine got that high....but also keep in mind that high chlorine tends to give falsely high pH results, so I don't really trust your pH result until the chlorine comes back down some.
    What is the ingredient in the "shock" and the "chlorine granules" that he added? If it was dichlor, which I think it probably was, it added some CYA. Also, the trichlor pucks that you are using add a great deal of CYA over time, plus you added a huge dose of CYA from startup, so that's why your CYA is suddenly so high. With a CYA that high, you do normally need to run higher chlorine levels to keep the water clean.
    You don't need to increase your calcium in a vinyl pool, so if you haven't added the other pound, I wouldn't. Calcium is necessary in plaster/gunite/concrete pools to keep the water from leaching calcium out of the concrete and making it brittle. In a vinyl pool, there is no concrete to protect. Brittleness in a liner is normally a result of sun damage, and/or out of whack water chemistry, not calcium deficiency. Mbar recommends a little calcium in her pool to help with the metals staining the water, but you do not need to raise it any higher than it is. That's a pool store thing--I think they tell you that you need calcium in a vinyl pool because that's what they've been told....and it doesn't normally make any discernable difference, but it's not needed.
    Edit: I see that Marie was typing at the same time I was--I will always defer to her on the metals front!!
    Jun 2010
    Hi,
    my pucks,shock and chlorine granules were all calhypo. (i do not have trichlor pucks.) I have been adding weekly dose of algecide the whole time since mem. day. it's hth algae guard 3x concentrate. the only cya i added was in beginning. the pool stain treat cleared my water quickly last time, but not really seeing any difference yet? i know to get my pH around 7.2, but where do i go next for my chlorine level to show. I was told not to shock unless i really need to so how can i get my FC at 5 w/o shocking and turning my water brown again?(if it ever clears) I am now mad since i wasted another $15 on calcium, lol. (keep in mind since mem day i have added 32 oz of metal out, 32 oz of hth metal control, and 32 ozs of united chemical's metal treat. this all went into my 5000 gals of water. then on top of that a whole bottle of pool stain treat.) do i need more sequestering agent? and with my iron level so low why does it still turn brown? please bare with me. every time i think i'm one step ahead, i fall 10 behind.
    mbar's Avatar
    Ashland, PA
    5 ppms of chlorine in your pool is not shock level. To take your pool up to shock level with a cya of 60 would be 20ppms. The only thing I can think of is that your cya didn't register right away at the beginning, or the test is wrong. That is why we recommend you have a really good test kit. This way you can test your own water and the results will be consistent. I think you need a little POP (pool owners patience) You are putting in too much stuff. It takes chemicals a while to work, and sometimes if you put too much in a small amount of water it will all react against each other, and then you won't know what is working, and what is not. I know that it is very frustrating. Just check your ph, I think when it comes down, and the chorine is at 5 the iron will go back into solution. Your chlorine level should consistently be no lower than 5 with your cya level or you risk getting an algae attack. You don't need anymore sequestering agent as far as I can see. What is your calcium level? Calcium is a metal itself, if the level is too high now with the calhypo and the calcium you added, it could be a problem. You may have to drain and refill a third of the water to get rid of the calcium - Let me know how you do, I am pullin for you
    Northeast PA
    Jun 2010
    If my calcium in normal should i just go to using bleach? if so, please direct me. also, stopped at this other pool store today on my way to work to check out their prices on sequestering agents. I did not spend any money this time. How long do you think i should wait before i try another sequesterant if the water doesn't clear? they had this 1/2 hp sand filter made for intex pools for $239. do you think that would be worth the investment if i ever get this water under control? Patience, what is that, lol.
    Quote Originally Posted by newpoolgirl View Post
    Hi,
    Are you SURE? That's very unusual, but not impossible. Removing metals with cal hypo is different than with triclor, and can be more successful. But, I'm not sure if you could do it on an Intex with no skimmer.
    PoolDoc
    Jun 2010
    pool doc
    that's what the bottles and bucket said was calcium hypochlor.... There is a skimmer on the pool. it hangs in water and screws to side(metal frame pool) then there is hose that goes from skimmer to liner adapter on inside of pool.
    I guess the one I'm really suspicious the container of "pucks" -- make SURE they are cal hypo. If they are, and if you are using ONLY cal hypo or bleach to chlorinate AND if you have a skimmer . . .
    . . . then there may be a way to remove the iron.
    But verify the pucks, first. Bad things happen with trichlor and cal hypo when they get close to each other.
    PoolDoc
    Jun 2010
    The chlorine pucks are made of:
    calcium hypochlorite 47.6%
    other ingredients 52.4%
    last night when i talked to my husband from work around 730pm, he said the pool water was the worst it has ever been. i looked at it this morning and he was right. so dark that i can't even see bottom. this has never happened to me before where it has gotten worse. We are changing the filter cartridges constantly. Do you think i should just just go buy that sand filter?
