Thread: testing salt
    Jun 2010
    new york
    Default testing salt
    I want to purchase a test kit. I've been directed to the Taylor K-2006. This test kit does not include a salt test. Is it necessary to test your salt or as long as the FC and other levels are good the salt doesn't need testing?
    Default Re: testing salt
    Do you have a salt water chlorinator? If so, then you need to be able to test your salt level. You can buy just that component and still get the Taylor kit. If you do NOT have a SWC, then you don't need to test salt levels.
    Jun 2010
    new york
    i do have a SWC. any recommendations for salt testing? i am about to order the taylor kit from amatoind.com per your recommendation from another thread. thanks
    May 2010
    Quote Originally Posted by purplegirl View Post
    The last time I surveyed www.amatoind.com they weren't carrying the Taylor K-1766 salt drop test, but you can always ask them about it when you place your order (or call them). If the price is retail ($23.70) or less, buy it at the same time as the K-2006.
    Otherwise, try the following sources
    PoolWeb.com
    NationalPoolCare.com
    Novatech-usa.com
    Saltwaterpoolparts.com
    Other distributors carry it at full retail price.
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
  1. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  2. Testing for salt
    By dedkrd in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-16-2010, 10:11 AM
  3. Salt water level testing
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2007, 09:51 PM
