Re: reagents
It was some sort of organic acid, but I don't think they specified which one and I don't think it was acetic acid. [EDIT] Anna listed the MSDS contents for me and it only had acetic acid (which is an organic acid) but at fairly low concentrations along with sodium acetate so that could be used as an buffer to have the pH be low. [END-EDIT]
