Results 1 to 10 of 15
Thread: Hayward Pump questions
    Maine, USA
    Default Hayward Pump questions
    I currently have a Hayward Super Pump, 3/4 HP that has been in use for over 15 years. I feel that the pump is on its last legs as it's getting more noisy this year as time goes on. Sometimes it's fine and other times, it's very noticeable.
    In any event, a little background: I have a Hayward Micro-Clear DE-3600 Filter (flow rate 72 GPM). The pool is an in-ground 16x32 vinyl, @20K gallons. I installed solar panels on my roof last year and the rise is about 25 feet. The pump has handled this perfectly fine, but I'm wondering if it could stand a bit more horse power (maybe it caused the current pump to work slightly harder and attributed to it slowly failing?).
    My questions:
    Would it hurt to get a 1 HP pump replacement or should I stick with the 3/4 HP? Or conversely get even more HP?
    And the pump description says it "must be hard wired". My current pump simply plugs into a GFCI standard 115VAC receptacle and is controlled by a switch above. Hopefully "must be hard wired" means I have to manually add the power cord? Or does it mean it must be hard wired to the circuit (w/o the receptacle)? Obviously, the receptacle's convenient as I store the pump away for winter.
    Regards,
    Ron [ muvipix.com ]
    Honesdale PA
    Default Re: Hayward Pump questions
    Hi Ron,
    The pressure gauge will tell if you're taxing the pump. What kind of pressures do you normally run? 15 years? Part of me says if it lasted this long then it's good for another 15. Joking. Really depends on what is causing the noise. One or both of two things. Water pressure seal or bearings. The fact it is at times quiet still doesn't point to one or the other.
    If you do replace it and that size has been working fine then stick with the same and save electricity. As for the solar 25' in the air, once it is filled with water it may as well be laying flat on the ground. Takes a little more poop to get the water up there but once filled, gravity helps on the downside.
    Tell us the pressure and that may change our thoughts.
    Maine, USA
    Wow, fast responses here
    Pressure runs at about 16-17 PSI without the panels and 18-19 PSI with the panels. When I port the panels, I do have to restrict the flow on the output a tad (I use washers inside the outlet jets to do this) to add more pressure to purge air (I assume at the top of the panels). But this is what sends it from 18 to 19 PSI. I have a ball valve; I just haven't installed it yet.
    Not a significant difference as you can see. And I can get the 1 HP pump for the same price as the 3/4 HP at Amazon (The 1 HP being free shipping), so I figured I might as well get the 1 HP - only if it would help. I'd like to save electricity too!
    What do you think?
    Regards,
    Ron [ muvipix.com ]
    mas985's Avatar
    Pleasanton, CA
    I wouldn't go any higher than a 3/4 HP. In fact, I am running a 1/2 HP (full rate) pump with solar and a 25' roof without any problem. The panels prime fine in less than about a minuite.
    Also, I am surprised you need to restrict the returns at all. You shouldn't need to do that with only a 25' rise. Again, I am able to prime my panels with about 15 PSI. Have you tried it without the restriction?
    Mark
    Maine, USA
    Quote Originally Posted by mas985 View Post
    You've convinced me, thanks.
    If I run it without the restriction, it bubble-burps every several seconds or so. Not a major problem, but it does cease when I restrict it
    Regarding the electrical... has anyone purchased a new pump recently? Will I just be able to remove my current cord and install/wire it on the new pump? Or have things changed in that arena?
    Regards,
    Ron [ muvipix.com ]
    mas985's Avatar
    Pleasanton, CA
    Do you currently have the SP2605X7 pump (uprated 3/4 HP)? If so, that pump actually has a lower head curve than my 1/2 HP pump which might explain why you have having some trouble with priming. What is the filter pressure when you don't have the extra restriction?
    Mark
    Maine, USA
    Hi Mark,
    No trouble with priming, just the air. The pump model number is SP1605 Z1...
    Without the washers in the outlets, I get about 17 PSI or so. It's not much of a difference at all with/without restriction, but it does get rid of the air when I increase the pressure slightly.
    Regards,
    Ron [ muvipix.com ]
    Ron, I'll gladly leave pump size and flow issues to experts like Mark and Al (if I know a little about what they're talking about, it's only from reading their threads )
    However, it's easy, usually, to see if the shaft seal has failed, all you need do is look for a drip at the motor/ housing interface when the pump is running (a puddle coming from under said interface is a good indication as well)
    Good luck with keeping the motor running another 15 years.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by rhosk View Post
    Hi Mark,
    That is actually the motor number but it is the motor for the SP2605X7 model pump which is a 3/4 HP uprated pump. The SP2607x10, an uprated 1 HP, is actaully closer to the 1/2 HP pump that I have in terms of performance (not all pumps are created equal).
    What may be happening is that the pressure at the vacuum release is not high enough to completely close off thereby allowing air into the panels. So the panels go through a cycle of air and purge which is why you see bubbles come out periodically. So the issue could be with the valve itself.
    However, 17 PSI should be more than enough pressure to close the VRV and prime the panels unless there is a lot of head loss between the filter and VRV. What size pipe do you have going to the panels? Where is the VRV located? Sometimes you can move the valve to the supply side of the panels so it closes off easier.
    Mark
    Maine, USA
    Hm, this thread has strayed off topic, but as usual, I'm learning more and more!
    I have about 40 feet of (2") PVC level ground, then the 25' rise to the panels, then the same returns. The VRV is at the top most position of the panels.
    This sounds interesting. I may have to try this.
    Regards,
    Ron [ muvipix.com ]
  1. Questions on changing to a 2 speed motor on a Hayward Super II pump
    By keastman in forum Pool Equipment & Operations
    Last Post: 05-01-2012, 01:10 AM
  2. hayward pump help -
    By haeffnkr in forum Pool Equipment & Operations
    Last Post: 07-24-2008, 11:42 AM
  3. Hayward Light questions
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 08-15-2007, 05:34 PM
  4. Hayward Pool Vac Questions
    By CelticDaddio in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-16-2007, 06:34 PM
  5. Pump seal for Hayward super pump?
    By goosegunner in forum Pool Equipment & Operations
    Last Post: 05-22-2006, 01:34 AM
