Results 1 to 10 of 20
Thread: IN CANADA: Where to buy Taylor Test Kit???
Threaded View
  1. #6
    Default Re: IN CANADA: Where to buy Taylor Test Kit???
    Quote Originally Posted by sturev View Post
    I'm thinking the $170, might be the K-2006C, not the K-2006... you should find out because the C, has 2 ounce reagents and the other has .75 ounce ones.
    Nope, if you check the link I gave you will see that the K-2006 is $143.50 and the K-2006C is $345.00 (and that is Canadian dollars, in US dollars the kits would be $138.99 AND $334.17. Sure seems that the exclusive master distributorship that Lowry has allows them to set the prices ridiculously high. Don't know since I am in the US but I suspect that Lowry charges their customers high wholesale prices and since they are "the only game in town" the dealers are getting the shaft as well as the consumers (since Canadian dealers must order from Lowry and cannot order directly from Taylor).
