Results 1 to 10 of 11
Thread: Question about solar panels
    farmgirl is offline Registered+ Thread Analyst farmgirl 0
    Default Re: Question about solar panels
    AHA! I went home on lunch hour to see if the panels would do anything different with a few adjustments. I read earlier that if your flow from your pump was too strong, you may get incomplete flow thru the panels. So, I diverted the water flow by half, and guess what........with the water diverted, and the pump on the HI setting, ALL the panels turned cool (ie, they were working!) Weird, but i still do not understand why the 2 center panels do not work if the pump is on low. Any ideas? I did not think this was so complicated!!!
    Hertford, NC
    (about an hour west of the Outer Banks)
    24 foot round above ground
    Question:
    Are you feeding the panels on the lowest point or the highest point?
    It's probably best to feed at the lowest so any air pockets can get pushed out.
    I would still take one endcap on each of the suspect panels off and see if you can push a stick/rod through to the other end cap - who knows, maybe the labels are applied wrong - unscrewing the caps is not much work so it may be worth a try.
    Another thing is that trapped air may then escape and alleviate this issue in the future.
