Higher chlorine levels with lower CYA levels do tend to be drying--but if you're keeping your Cl levels in line with CYA, you shouldn't have much of a problem. The girl that cuts my hair tells me that if you'll rinse hair with tap water before going into pool and again after, that it helps decrease the drying. A good conditioner helps, too.
