Re: Poolsean: AutoPilot Pool Pilot settings for new pool
waterbear
No. The idea of the power levels so you operate in the middle of a power range so the auto temp compensation can do it's job. If you need to operate at 20% output or below then drop to a lower power level and restart at 50% and readjust from there. If you need to operate at 80% output or higher then move to a higher level.
I will restate what I said a different way. Start on level 2 and if you CAN maintain the desired FC level with your output set between 20% and 80%
then stay on level two.
If you have go below 20% drop to level 1 and start around 50% and adjust until the FC is where you want it.
if you have to go above 80% the move up to level 3 and start at 505 and adjust until the FC is where you want it.
Gotcha, makes sense now. I'll take some readings and determine the correct setting. Thanks for the explanation. The manual is not clear at all regarding the power level settings.
16' x 32' IG Vinyl
Autopilot Digital 220 w/SC-48 SWG system
Cooper 25" sand filter with 1HP pump
16'x32' rectangle 22.5K gal IG pool; SWCG; Cooper 25 sand filter; ? 1.25hp pump; 8hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; utility water; summer: ; winter: ; android phone; PF:5.3
