Results 1 to 3 of 3
Thread: sand filter
    Jun 2010
    1536 treviso ave
    Default sand filter
    I found there are some sand like stuff on the pool floor. How can I tell it is sand leaking from filter or some surface dusts sinking to the floor?
    chuck
    Default Re: sand filter
    Best way I know -- for your own pool -- is to swim down and feel it. Sand feels, well, sandy. Dead algae is powder and may float away when you try to touch it. DE (not that you should have any, unless you have a DE filter) is sort of a very fine but gritty powder.
    PoolDoc
    Welcome to the forum!
    While Ben's suggestion has a certain 'gritty' practicality to it () - what I do is rubberband a nylon to one of the returns and check whatever it catches, this also removes blown in debris from the equation (And you don't have to get in the pool to perform the test.
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    By MikeInMo in forum Pool Equipment & Operations
    Last Post: 05-31-2007, 12:01 AM
  4. Sand in bottom of pool from sand filter
    By nicole12 in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
