Re: Pump shaft bent
Wow....takes a bit to bend a piece of steel like that. Would sure like to know what caused it.
Debris in the impeller or any amount of DE should not bend anything. Hard debris like nails, screws, bolts, etc. could gouge or destroy the impeller and housing. It is probably possible to bend a shaft if something BIG and hard, like a bolt, gets past the baskets and jams the impeller while it is up to speed.
As for spinning down when turned off....if it was pumping water when power is cut it will stop fast. If dry then it will wind down over many seconds. When pumpig water it is under load but dry it should just turn freely.
As for bending the shaft by beating on the motor case, I doubt it.
I did bend a shaft one time on a Hayward AG pump but I was trying to press off the fan to get to the bearing behind it. Rusted real bad. The 20 ton press won and the shaft lost and the rust never did break loose and that was after trying every rust breaking trick I know. Replaced it with a good Superpump.
