Results 11 to 15 of 15
Thread: Adding CYA
    Lehigh Valley, PA
    Default Re: Adding CYA
    Leslie's is where I usually get the R-0014 since my preferred online vendor also doesn't carry it.
    I wanted to add a 'heads up' in reference to adding CYA slowly via the skimmer. While it will get transported into the filter eventually it first sits in the pump pot for a while. This might be disconcerting to someone who hasn't used the skimmer method previously.
    It takes about 20 minutes for my water flow to clear approximately 1 pound CYA out of the pump pot. I have a 2-speed pump and set it on 'high' when I make this addition.
    Just file it away in your 'Oh yeah, didn't I read about this?' memory.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
    May 2010
    Central NJ
    I have bought on-line from Amato and Taylor directly. Very happy with both. Fast shipping and easy to deal with. Amato has better prices. Riddle me that? Both got me my product in a few days. Amato charged $11.00 for shipping, Taylor shipped free (built-in). Even considering this, Amato was still a good bit cheaper.
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by AnnaK View Post
    LIke I said, add it SLOWLY! I put about a half cup at a time in and wait a bit before adding more.
    May 2010
    I added CYA by the sock method. I would like to know what the acceptable chemical balances would be for my type of pool;
    I have a gunite IG 14 x 28 approx 17500 gals:
    My latest readings:
    Chlorine 1
    Ph 7.2
    Alk 100
    CH 160
    CYA Just added and am waiting before testing.
    My Ph, Alk, CH have dropped alittle from a few days ago. Any advice on what levels to achieve and maintain? Thanks much!
    May 2010
    Quote Originally Posted by utahpool View Post
    My latest readings:
    Chlorine 1
    Ph 7.2
    Alk 100
    CH 160
    I can't believe there isn't a sticky on recommended levels (I looked but couldn't locate one)!
    Unless there was a lot of water lost from your pool this week the drop in Calcium Hardness is probably due to testing variability.
    Free Chlorine (FC) should be aligned to your target/actual CYA level. See this chart or target a minimum FC of 5% of CYA (SWG) or 8% of CYA (no SWG). For example, if you have added enough CYA to achieve a 50 PPM level, keep Free Chlorine at or above 2.5 (if pool is chlorinated by SWG or liquid chlorine automation), 4 PPM otherwise.
    So, chlorine appears to be too low. pH is within acceptable range, TA is fine, CH could probably come up a bit. I like to use the Pool Calculator to determine the saturation index when trying to balance Alkalinity, calcium hardness, pH, salt etc. It will also display recommended levels if you enter the type of pool you have.
    16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
