Results 1 to 10 of 15
Thread: Adding CYA
    May 2010
    Question Adding CYA
    What is the proper way to add CYA? I have 4 pounds and my CYA reading is 0. My pool is 17,500 gallons. Also where is the best place to by reagents online? I know this has probably been discussed before but I can't find it. Thanks for your help!
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Default Re: Adding CYA
    Amato sells the reagents and has been a great place for me...
    Here's a link to their site:
    http://www.amatoind.com/taylor-testi...s-c-30_35.html
    For the CYA, put it in a old sock and hang it in front of a return jet and it will slowly dissolve. You can even squeeze on it every once in a while to help it break down. It will take a while to get in the water and show up on a test. I'd add 3/4 of what you think you need and then wait a week or two and test as you can always add more but removing it means a partial drain and refill
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    May 2010
    Thanks for the advice and the link!
    May 2010
    Old sock like a nylon or a regular type sock? I'm learning! lol
    sturev's Avatar
    May 2010
    I used a old thin white cotton sock, but I'd think nylon would work also...
    Evan S.
    I just slowly pour it into the skimmer with the pump running and let it collect in the filter where it slowly dissolves. Don't backwash or clean the filter for a week. Been doing it for years with no problems (and this is also what I have heard in manufacturer's product trainings).
  1. low pressure when adding DE.
    By Amir in forum Pool Equipment & Operations
    Last Post: 05-24-2009, 06:10 PM
  2. Adding BBB
    By Water_man in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-22-2008, 09:00 PM
  3. adding cya
    By tara15 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2007, 09:05 PM
  4. adding cya to pools
    By cleland418 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 03:16 PM
  5. Adding CYA
    By satj in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2006, 11:07 PM
