Results 1 to 10 of 15
Thread: Adding CYA
    Default Re: Adding CYA
    I just slowly pour it into the skimmer with the pump running and let it collect in the filter where it slowly dissolves. Don't backwash or clean the filter for a week. Been doing it for years with no problems (and this is also what I have heard in manufacturer's product trainings).
    May 2010
    Thanks for the advice!
    I use the skimmer method, too. I get most of my reagents from http://www.spspools-spas.com. Shipping is quick, prices are good, and they've always been very courteous and helpful-- but then again I call them and tell them what I want, I don't ask them for advice...
    Lehigh Valley, PA
    Janet, about SPS, I'm putting together a refill list and thought I'd give them a try but I don't see where they have the Taylor R-0014 pH reagent. Am I just not finding it? Do you get that from them?
    No, I think I got the last one at TaylorTechnologies.com. I have also bought it in the store at Leslie's, when I'm in a pinch
    Lehigh Valley, PA
    Leslie's is where I usually get the R-0014 since my preferred online vendor also doesn't carry it.
    I wanted to add a 'heads up' in reference to adding CYA slowly via the skimmer. While it will get transported into the filter eventually it first sits in the pump pot for a while. This might be disconcerting to someone who hasn't used the skimmer method previously.
    It takes about 20 minutes for my water flow to clear approximately 1 pound CYA out of the pump pot. I have a 2-speed pump and set it on 'high' when I make this addition.
    Just file it away in your 'Oh yeah, didn't I read about this?' memory.
    May 2010
    Central NJ
    I have bought on-line from Amato and Taylor directly. Very happy with both. Fast shipping and easy to deal with. Amato has better prices. Riddle me that? Both got me my product in a few days. Amato charged $11.00 for shipping, Taylor shipped free (built-in). Even considering this, Amato was still a good bit cheaper.
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    Quote Originally Posted by AnnaK View Post
    LIke I said, add it SLOWLY! I put about a half cup at a time in and wait a bit before adding more.
    May 2010
    I added CYA by the sock method. I would like to know what the acceptable chemical balances would be for my type of pool;
    I have a gunite IG 14 x 28 approx 17500 gals:
    My latest readings:
    Chlorine 1
    Ph 7.2
    Alk 100
    CH 160
    CYA Just added and am waiting before testing.
    My Ph, Alk, CH have dropped alittle from a few days ago. Any advice on what levels to achieve and maintain? Thanks much!
