Thread: Pool Pilot piping and Heater
    New Orleans
    Default Pool Pilot piping and Heater
    I have my PoolPilot soft touch on order and am planning the piping changes needed. I have heard that the cell should be the last thing in the system before the water returns to the pool, but I wonder about the heater. What is the correct configuration.. cell before or after the heater?
    This is a 20K gallon IG pool, no spa, with pump, sand filter and natural gas heater.
    Putting the cell before the heater potentially increases the corrosion rate of the heater due to Cl content of the water, while putting the cell after the heater exposes the cell to hot water when the heater is in use, which might be bad for it and certainly messes up the temperature compensation.
    22,000 gal IG, Tagelus 60 Sand filter, 1.5 HP Pentair Challenger and a very dead heater.
    Ft Lauderdale, Fl
    Default Re: Pool Pilot piping and Heater
    Allow about 4' of pipe before the manifold. This will allow some cooldown of the water before it hits the tri-sensor. Yes, the automatic temperture compensation feature will increase the output based on the heater temperature increase. However, this may be about 7 - 10 degrees increase and shouldn't affect the Soft Touch's output much.
    Sean Assam
  1. Heater Pilot Won't Stay Lit
    By hayshaker170 in forum Pool Equipment & Operations
    Last Post: 06-28-2011, 02:29 PM
  2. Hayward H200 heater pilot will light but unit doesn't get very warm
    By Joe Stephen in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 10:47 AM
  3. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  4. Pump and Heater Piping
    By MaxxFusion in forum Pool Equipment & Operations
    Last Post: 05-06-2009, 10:43 AM
  5. Piping filter/pump/heater. Any tips?
    By cruzmisl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2007, 11:52 AM
