Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: The Great Nature2 Debate
  1. #21
    Default Re: The Great Nature2 Debate
    Just lining up ducks . . .
    Nature2 Patents:
    5352369-Henig-Fountainhead-Method of treating water
    http://www.freepatentsonline.com/5352369.html
    http://www.freepatentsonline.com/5352369.pdf
    5660802-Henig-Fountainhead-Water purifier
    http://www.freepatentsonline.com/5660802.html
    http://www.freepatentsonline.com/5660802.pdf
    5766456-Denkewicz-Fountainhead-Water purifer for a pool
    http://www.freepatentsonline.com/5766456.html
    http://www.freepatentsonline.com/5766456.pdf
    5779913-Denkewicz-Fountainhead-Water purifier for a spa
    http://www.freepatentsonline.com/5779913.html
    http://www.freepatentsonline.com/5779913.pdf
    5858246-Henig-Fountainhead-Method of water purification with oxides of chlorine
    http://www.freepatentsonline.com/5858246.html
    http://www.freepatentsonline.com/5858246.pdf
    6093422-Denkewicz-Zodiac-Biocidal compositions for treating water
    http://www.freepatentsonline.com/6093422.html
    http://www.freepatentsonline.com/6093422.pdf
    6200487-Denkewicz-Zodiac-In-line,in-pool water purification system
    http://www.freepatentsonline.com/6200487.html
    http://www.freepatentsonline.com/6200487.pdf
    6254894-Denkewicz-Zodiac-Silver self-regulating water purification compositions and methods
    http://www.freepatentsonline.com/6254894.html
    http://www.freepatentsonline.com/6254894.pdf
    6524540-Henig-Biocatalytica-Materials and methods for water purification
    http://www.freepatentsonline.com/6524540.html
    http://www.freepatentsonline.com/6524540.pdf
    PoolDoc
  2. #22
    More ducks . . .
    Zodiac Pool Systems EPA registrations from http://ppis.ceris.purdue.edu/ :
    Interestingly, there does not appear to be an active sanitizer registration for Zodiac involving monopersulfate.
    Firm Number: 67712
    ZODIAC POOL SYSTEMS, INC.
    6000 CONDOR DRIVE
    MOORPARK CA 93021
    805/529-2000
    Number of Selected Products: 3
    NATURE2 G45-VC40
    Registration Number: 67712-1
    Status: Active
    Approval Date: 11-21-02
    Product Manager: Marshall Swindell (703)308-6341
    Percent Active Ingredient
    8.2300 Copper sulfate pentahydrate (24401)
    3.5100 Silver (72501)
    NATURE2 AG
    Registration Number: 67712-5
    Status: Active
    9.4300 Copper sulfate pentahydrate (24401)
    2.3300 Silver (72501)
    NATURE2 SPA
    Registration Number: 67712-15
    Status: Active
    Approval Date: 02-16-06
    0.9200 Silver (72501)
  3. #23
    The MPS / Nature2 Missing Registration Mystery
    Searching in Purdue U's database of EPA registrations
    http://ppis.ceris.purdue.edu/htbin/epachem.com
    for:
    Potassium monopersulfate
    Oxone (Dupont trade name)
    37222-66-5 CAS number
    I came up with zip.
    BUT, Nature2 claims to have a registered spa sanitation system, involving MPS
    http://www.nature2.com/spaproducts/nature2spa.asp
    "If used with MPS, the most recommended spa oxidant, Nature2 Spa becomes a complete spa sanitizing system - the only non-chlorine spa sanitizing option available. And managing your spa is easier than ever; Nature2 Spa slips into your spa filter and lasts up to four months."
    http://apps.cdpr.ca.gov/cgi-bin/labe...l?prodno=54550
    I did find a more complete set of approved labels, with other information. I'll have to explore this later:
    http://apps.sd.gov/doa/prrs/search/P....asp?key_m=779
    Found the MPS Spa "recipe":
    https://apps.sd.gov/doa/PRRS/ImageVi...47156&Type=pdf
    That's all for tonight.
  4. #24
    Ben, I sent you a PM.
    Also, check out this thread which had both the old and new spa low chlorine recipes in it.
    http://www.poolforum.com/pf2/showthread.php?t=5446
    I posted it in 2006 when Zodiac changed the instructions and came out with the "NEW" low chlorine recipe which works out to maintaining about a 2-3ppm FC in the spa and shocking to about 10-12 ppm as compared to the "OLD" recipe that shocked the spa to 6 ppm on startup, kept a .5 ppm residual, and "as needed shocking" to 2 ppm. Wonder why they made the change in 2006?
    Interestingly enough, the current spa instructions on the US website have a 2007 copyright and they have upped the 'as needed shocking" with dichlor to a higher FC level, about 10-12 ppm. Hardly a low chlorine recipe at all.
    In the original recipe MPS was an option for the as needed shocking, in the 2006 and 2007 instructions the use of MPS as shock is no longer done but dichlor is used instead.
    Also, here is an interesting link from Zodiac Australia. It is the Australian instructions for the N2 express. FC is kept at a minimum of 1 ppm and higher levels for indoor or stabilized pools. They then go recommend stabilizer levels of 50 ppm! (Is this a sneaky way to say that FC needs to be higher than 1 ppm with a N2?)
    http://www.zodiac.com.au/media/29825...s%20manual.pdf
    I know that the APVMA (Australian government entity that controls pesticides and swimming pool chemicals, much like our own EPA,except their guidelines for pool and spa sanitizers seem to be more stringent than ours) did recall the Nature2 in 2004 because of the very low chlorine levels they were suggesting (much like the US instructions still do)
    http://www.apvma.gov.au/publications...tte0403p14.php
    They also recalled the N2 spa carts because of the MPS only options (which changed in the US in 2006 to require chlorine in the recipe for shocking)
    http://www.apvma.gov.au/publications...tte0406p26.php
  5. #25
    All very interesting.
    The change from the original Fountainhead patents to the current incarnation is interesting. It appears that the old product focused on what happened inside the cartridge while the new ones are merely passive "mineral-izers".
    Again, it looks like Henig STILL believes that something real was happening in his unit; he has newer patents along that line. But Zodiac and Denkewicz seem to have given that up. There was some justification for the "'active oxygen" and catalyst language dealers have used, in that Henig and other Fountainhead folks seem to have believed it. (Who knows: it might even be true!) But, it doesn't apply to the current Nature2, at all.
    Seems to be an example of a corporation seeing value, not in the actual product, but only in the brand name.
    Ben
  6. #26
    Yet, at best, it still comes out to a very expensive "solution" to the fear some people have of chlorine, a fear I've yet to see justified. I'd be guessing at the statistics but I'd say for every person actually truly sensitive to chlorine and bromine, there's a VAST number that think they are, when it fact they are merely sensitive to a poorly maintained pool--as most of us are!
    Carl, I think a lot of the problem goes back to the fact that a lot of people have
    1. Experienced skin or eye irritation in pools that were . . .
    2. Chlorinated.
    The whole FREE / COMBINED distinction is to them a "distinction without a difference", because the chlorinated pools they have encountered were irritating.
    Ben
  8. #28
    2. Chlorinated.
    Ben
    Ben,
    Exactly!
    Eat a spoiled piece of fish and it puts you off fish, which has nothing to do with fish itself.
    Then if this really IS the case it means that the only sanitatin takes place INSIDE the unit, whch makes it no better as a sanitizers than an ozonator or UV sanitizer. The only water that is being sanitized is inside the chamber! Once again this means that a fast acting residual sanitizer at levels that are effective needs to be present in the water.
    It IS all very interesting!
  1. Nature2 Pool
    By Dawg85 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-19-2012, 04:57 PM
  2. Saltsystem? Nature2?
    By oroepke1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-09-2010, 12:52 AM
  3. Chlorine pool and the Nature2
    By BUCKEYEPOOL in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2010, 01:00 PM
  4. 2 speed pump or not? Also the great DE debate!
    By skamp in forum Pool Equipment & Operations
    Last Post: 03-01-2007, 12:13 PM
  5. Nature2 Purifier?
    By Calicowinks in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2006, 03:59 PM
