Results 1 to 10 of 13
Thread: Crack in Hayward Super pump housing wth pics
    Jun 2010
    Default Crack in Hayward Super pump housing wth pics
    Hayward EC-75 and Super Pump of unknown HP. The filter is brand new but the pump is 10-15 years old.
    My pump has been having some performance issues. Seems like an air leak in the
    system somewhere, could this be the cause? Also the concrete around the pump base is always wet (but not soaked). The crack is inside the pump housing
    in the wall that separates the basket from the pump motor. Do I need to replace
    the pump housing, or can I fix it with putty or epoxy?
    I am currently replacing the diffuser gasket and housing gasket, but I can't get to the seal because the screws have rusted over and I can't get the rear cover off the pump motor.
    Pump housing from above:
    A closer shot of the crack:
    And a shot from the motor side of the pump housing:
    Default Re: Crack in pump housing (wth pics)
    Hi Bob;
    FYI: For the protection of other PF users, live links are a feature only available to established subscribers, and long term users.
    But, I looked at your crack -- it's definitely in the suction section of the pump casing, and appears to extend as a hairline all the way to the exterior. So, if it's not allowing air in yet, it will.
    However, it looks like your pump may have run dry, which can mean problems elsewhere. Given all the other pump issues, it seems like there are three questions you need to answer:
    Q: Could someone repair my pump? A: Probably. Given the right epoxy (NOT Pool Putty!), a die grinder with a carbide burr, and a lot of time and patience, I probably could -- if there are not cracks in the threaded areas.
    Q: Could you repair that pump? A: Given that you have to ask, probably not, at least not in any amount of time or $$ that makes sense.
    Q: Should you repair that pump? A: Unless you've got overwhelming budget issues, I'd say it's time for a new one. 10+ years is a good lifespan for a non-commercial pump.
    PoolDoc
    Jun 2010
    Thanks for your input! No worries about reviewing the links, I know that security is a big concern for forums like this. I just thought the pics were important to understand the crack.
    I would like to attempt to repair the pump housing if the alternative is a new housing/motor anyway. Can you recommend a putty to use, and is a die grinder really necessary or could I use a regular metal file or rough sandpaper?
    Replacing the pump may be a challenge as the info for the motor has long since worn away by the elements and my late father is the only one who would know for sure what HP it is. It is a 20'x40' in ground pool, ten feet deep, piped with 1.5" plumbing and a Hayward Perflex EC-75 filter (brand new, replaced an old EC-60 this season).
    Thank you very much for your help!
    You have a Hayward SP26xx model pump -- see here:
    http://www.haywardnet.com/inground/p...m?ProductID=10
    Regardless of anything else, with 1.5" piping you are limited to about 40 GPM. I don't know what other piping you have, so I can't be sure, but a Hayward SP2607X10 should do fine. If you aren't budget constrained, a two speed SP2607X102S will save quite a bit over time, especially with a DE filter.
    On your existing pump, I'd just knock the head off the screw and be done with it. Trying remove a rusted steel screw from an aluminum pump end (what it probably is) is not the best task to spend time on, when 2 screws will still hold your pump end bell on.
    PoolDoc
    Jun 2010
    PoolDoc thanks so much for your help. Thanks also for combining the post about the screw with this one.
    I reassembled the pump housing and motor with a new diffuser gasket and housing gasket. I filled the reservoir with water and just watched it. Sure enough, slowly water started to come out from under the pump housing. Whether it is the crack in the pump housing or a failed mechanical seal there is definitely a leak in this pump. I am going to take your advice and replace the pump entirely.
    The most I can make of what's left of the model# is SP XXX5-7-1-M. At least that's what I think it says. I realize this means it should be the 3/4 HP model, but the store we bought it from recommends the 1.5HP for this pool and my mother insists we bought the 1.5HP model.
    PoolDoc, do you have any links that explain how to calculate feet of head?
    Please don't succumb to the "Bigger Pump" scam. If you ran FINE with a 1hp for years you don't need more. The smallest 2 speed Hayward sells is a 1 hp SuperPump. I have this and it's been running for 8 years.
    How big is your pool (did I miss that?)? I have 20,000 gallons so...unless you have a much bigger pool you won't need more than that.
    Jun 2010
    Default Drill out a stuck screw on a Super Pump motor?
    I am trying to replace the seal assembly on my Hayward Super Pump. Two of the three rear screws came out easily, but the third is locked in and when I try to take it out it slowly stripping the screw head. I have tried lots of WD40 to no avail. Can I drill the screw out if I am careful not to let the drill go in too deep? I definitely do not want to drill the capacitor in there!
