Results 1 to 10 of 11
Thread: DE filter letting bugs through
    Jun 2010
    MA
    Default DE filter letting bugs through
    Just installed a salt system. However, the filter screen gets clogged frequently. I've taken my DE filter apart twice and looked for tears in the screen, holes in the plastic, but everything seems intact. Where can these bits of efluent (mostly small bugs) be coming from?
    Honesdale PA
    Default Re: DE filter letting bugs through
    Welcome to the forum.
    If the filter looks intact then I would suspect the valve. Don't know what kind of valve you have but multiports are notorious for having spider gaskets unseat and letting some flow bypass the filter. Someone more familiar with DE's should chime in.
    Smile Re: DE filter letting bugs through
    Welcome to the forum!
    If I'm supposed to chime in, I guess I will
    I gotta agree with Al, it's probably a multiport issue! Turn off the pump, close the valves to the pool and take a look inside it.
    I'm willing to wager that the spider gasket/ A/K/A wagon wheel is in need of replacing
    Just to cover my bet, which model of DE filter do you have?
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    What does a spider gasket look like?
    Honesdale PA
    It depends on the type of valve you have. We're assuming what is called a Multi-Port. The thing looks like a wagon wheel with oddly spaced spokes. If you have a different type of valve this does not necessarily apply.
    Here's a link:
    http://www.google.com/products?hl=en...ed=0CDgQrQQwAg
    Jun 2010
    MA
    Good suggestion. However, I took apart the Hayward Vari-flow and the spider gasket looked ok. It was a little worn, but no major flaws. I replaced it just to be sure. Is there anyway that the valve and attached openings can be off kilter? I did not see anything visibly wrong.
    I am beginning to suspect that I'm losing pressure from the DE somewhere. The internal pressure is not climbing above 12 (ten is normal after I backflush and clean), and usually by now, I've needed to backflush the filter a couple of times.
