Thread: Replacing reagents in the K2006 kit
Threaded View
  1. #3
    Default Re: What test reagents to replace from last years K2006 kit?
    See Recognizing a Compromised Reagent from the Taylor website. I list below the chemicals found in various kits, grouped roughly by shelf life based on their content.
    Indicator Dyes and FAS-DPD
    (most sensitive; replace at least every 2 years if kept in cool dark place; if not cool, replace every year)
    • R-0004/R-0014 Phenol red pH indicator dye
      also contains a mix of proprietary chlorine neutralizers (not thiosulfate)
    • R-0600 Orthotolidine (OTO), chlorine indicator dye
    • R-0870 N, N-diethyl-p-phenylenediamine (DPD)
      powdered indicator dye plus phosphate buffer, EDTA and organic acid
    • R-0871 Ferrous ammonium sulfate (FAS), titrant reagent
    • R-0008 Bromocresol green and Methyl red, Total Alkalinity (TA) indicator combination dye
    • R-0011L 1 - (Calcon indicator), Calcium Hardness (CH) indicator dye
    Indeterminate shelf-life play it safe and replace every 2 years
    • R-0003 Potassium iodide
      used for combined chlorine (CC) test or total chlorine (TC) tests - sunlight plus oxygen oxidizes it
    • R-0007 Sodium thiosulfate, chlorine neutralizer
    • R-0012 Ethylenediaminetetraacetic acid (EDTA), Calcium Hardness (CH) titrating reagent -- published shelf-life 18-48 months
    • R-0013 Melamine, Cyanuric Acid (CYA) reagent
    Acids/Bases
    (least sensitive; essentially no degradation)
    • R-0005 Hydrochloric acid, acid demand reagent
    • R-0006 Sodium hydroxide, base demand reagent
    • R-0009 Sulfuric acid, for TA titration
    • R-0010 Sodium hydroxide, Calcium Hardness (CH) buffer
