Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Polyquat or not ?
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Default Polyquat or not ?
    Result of experiment of whether to add Polyquat at closing.
    Closed with Poly in fall 2005 and opened in Spring 2006 to clear water and clear bottom with CYA reading of 30. Believe it was 30-40 at close.
    Closed in Fall 2006 without Poly. Opened in Spring 2007 with clear water, but a film of dead algae on the the bottom and a CYA reading of Zero.
    Just wanted to post info for comparison by others. Maybe we can gather enough info to see if there is a correlation.
    Default Re: Polyquat or not ?
    I always close with poly. No algae on the floor but LOTS of black/brown soot/dirt/pollen. And clear water. Just comes with living in NJ. Even cloths in closets get covered in dust fairly rapidly. The Blue Dolphin gets it with 2 or 3 cycles.
    I have never closed without. I'm too scared at what I would find.....
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    This may be a testament to how a Cl shock will kill your Poly: I closed last fall with a double dose (half gal. in 20K of water) and then a shock, and while I can see the bottom in the four foot end, the deep end is dense green. I also use only a mesh leaf net as a cover.
    Note this post where a chemist at Buckman Laboratories gives the recommended closing procedure which shocks with chlorine first, then lets the chlorine level drop before adding PolyQuat.
    Richard
    OK, here's how I do it and EVERY season I open to clear water. I take into account that the PolyQuat in large amounts causes the FC level to collapse. But I don't do this until the water is AT MOST in the low 60's, colder is better.
    1) shock the pool
    2) Add 1 quart of polyquat.
    3) Wait 24 hours for the chlorine to drop.
    4) Shock it up again.
    5) Close
    Yes, it's really all it takes.
    nj, usa.
    I found it interesting that the CYA was at 0
    Wondering if the algae ate it last fall and then froze and dropped to the bottom.
    My CYA dropped from about 40 to 25 over the winter...but I had lot of dilution from rain and snowmelt
    Many people find their CYA level dropping to 0 over the winter. Though it is possible that algae eat it for food, what IS known is that there are anaerobic bacteria that normally live in soil that definitely consume CYA. It is very possible that at least for pools where the FC gets to 0 that these bacteria consume the CYA. If they do, then they produce ammonia as a by-product which would mean needing LOTS of chlorine to open a pool.
    Some users report the CYA dropping over the winter even maintaining chlorine levels. This happened to me this winter going from 20 to 10 (approximately) and I had no dilution (I have an automated opaque pool cover), but in past winter's I hadn't seen this and I've maintained chlorine levels every winter.
    Richard
    nj, usa.
    Alk is down too. 120 to 70.
    Lot of start up this year !! LOL
    Hate it when an experiment turns around and bites me in the wallet.
    I'll use poly this coming Fall and see what I find in Spring 2008.
  1. Where to Buy PolyQuat 60?
    By b2001 in forum Dealing with Algae & Slime
    Last Post: 06-13-2010, 10:28 AM
  2. polyquat
    By hannadock in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-11-2008, 12:53 PM
  3. How to use Polyquat
    By CTIGuy in forum Dealing with Algae & Slime
    Last Post: 09-08-2007, 02:28 PM
  4. PolyQuat??
    By Sam_I_am in forum Dealing with Algae & Slime
    Last Post: 07-29-2007, 10:45 PM
  5. polyquat
    By mikemedic in forum Dealing with Algae & Slime
    Last Post: 05-26-2006, 09:40 AM
