Results 1 to 10 of 19
Thread: i'm running my pump at night. bad idea ?
    Default i'm running my pump at night. bad idea ?
    in an attempt to stop the sun from burning out so much chlorine, i thought
    that keeping the water still during the day might help. so i run my pump 6:00PM to 6:00AM instead of during the day.
    (CYA is 50. I keep my chlorine between 3 and 6 as per ben's chart)
    so
    1. does this even make sense to do ?
    2. pool guy has warned against this saying it would promote algae.
    thanks in advance
    max
    Scottsdale, Arizona
    Default Re: i'm running my pump at night. bad idea ?
    I only run mine at night due to cheaper electricity during off peak hours.. I'm curious to see the debate on this one as well.
    At higher CYA levels, keeping the water still may help reduce chlorine consumption because the chlorine will mostly be degraded near the surface but the CYA will help to shield the chlorine from breakdown at lower depths. We don't know this for a fact, but this might be the case. If you try this, let us know if it works and by how much.
    As for when and how long to run the pump and for preventing algae, there are two reasons to run the pump:
    1) To filter the water. It doesn't really matter when the pump is run or whether it is done all at one time or spaced throughout the day. The main principle is how many turnovers of water (i.e. how much total water volume) is filtered per day. The rate needs to be high enough to filter the water faster than particulate matter builds up in it and this process is slow. Typically, one turnover per day is recommended, but this really depends on how much junk gets into your water. If the water looks dull or cloudy and its not an algae bloom (chlorine consumption hasn't gone up significantly) and calcium carbonate water balance is OK, then more filtration time is needed.
    2) To circulate the water. This can also be accomplished through stirring such as from a pool cleaner, but the pump plus strategic placement of the returns, skimmer and floor drain allow for even distribution of chemicals and for a circulation pattern that tends to cause floating debris to end up in the skimmer. It is this circulation function that helps prevent algae because a localized lowering of chlorine level in an area of the pool can allow algae to grow.
    So it is point #2 that your pool guy is worried about. By not having the pump on during the day, the lack of circulation could promote algae to grow during the time of day when their growth is most rapid (due to sunlight). I think the risk is low, especially if you maintain proper chlorine levels and do at least one turnover at night.
    Richard
    Caledon, Ontario, Canada.
    Chem Geek has the principals correct.
    I split my run time just so the water gets stirred up a couple times a day.
    Rent a gang of 10-12 year old boys to stir your pool everyday. They'll be happy to for pizza and soda!
    Scottsdale, Arizona
    Can I use 20 yo college girls instead ?
    Quote Originally Posted by maxhiller View Post
    so
    thanks in advance
    max
    In addition to the discussion above in answer to your question, just thought I'd throw a thought in, too... during the hottest part of the summer (remember I'm from Louisiana) I sometimes run my pump at night instead of during the day, too, because it helps cool the water and keep the temp lower...so the pool doesn't become a huge hot tub.
    it may just be a coincidence, but i developed algae.
    i've shocked and am back to daytime hours.
    - max
    North Florida
    FWIW, I try to follow Ben's sage advice over on poolsolutions.com...http://www.poolsolutions.com/gd/avoiding_algae.html...at least 6 hours of pump run time divided into at least 2 time periods.
    My electric provider has no difference in rates during the day, so I run more pump time in the daytime when I'm trying to warm the pool. Just like Janet (aylad) in LA, I schedule more run time overnight when I'm trying to cool the pool a bit. My pool water hit 90 yesterday so I guess I need to make some daytime-to-nighttime adjustments. Currently, I run 2 hours "over lunch" (11a-1p), 4 hours 4p-8p, and another 2 hours 3a-5a, for a total of 8 hours.
    Sandy
    Jul 2006
    West Central Illinois
    Quote Originally Posted by dawndenise View Post
    What kind of timer do you use?
    Bought/installed used Doughboy Summer 2006
    Husband is the muscle; I'm the mixer
    BBB
  1. Cost of running a pump 24/7
    By Guppy in forum Pool Equipment & Operations
    Last Post: 05-31-2012, 08:37 PM
  2. What to run at night with the pump.
    By xploded in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-13-2011, 07:47 AM
  3. pump running 24/7 or what?
    By airraid1999 in forum Pool Equipment & Operations
    Last Post: 07-09-2011, 06:39 PM
  4. Running pump at night?
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 08-07-2007, 07:59 PM
  5. running pump
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2006, 07:57 PM
