Hi Kirsten![]()
I know this wasn't a great season for pooling in the NEI hope you got some enjoyment out of the pool.
How low you can safely lower the water depends on the drainage under the pool - if you have a high water table or the snowmelt and spring rains will puddle under the pool, there is a chance of the liner floating - the more water in the pool, the less likely it will float.
r.e. the teflon tape - I assume you are using threaded plugs with an o-ring (i.e SP 1022-C). As long as the o-ring is in good shape, you shouldn't need the tape - unless, the faceplate is cracked or the liner wasn't fully cut out, a little flap of liner can keep the plug from fully sealing. As long as the plugs weren't bubbling after installed, the seal is good and you don't need to worry a bout it.
In the future when you blow the lines, let the air flow for 30 seconds then BACK OFF until the air is still coming out but not fountaining onto the deck (DH will surely appreciate this!) After the first plug is in, apply full force again for 30 seconds and back off again,... repeat for all lines. If you do it this way, the tape won't come off and DH won't get as soaked nor have as much trouble getting the plugs to screw in![]()
If DH saw bubbles after the lines were plugged, I'd go ahead and reblow them as I described, otherwise, I'd say you're good for the winter.
Have a great winter and I look forward to seeing you here next season![]()
