Results 1 to 10 of 19
Thread: J-channel holding liner in corner broke off, liner is sagging
    Ohio, North Canton
    Default Re: J-channel holding liner in corner broke off, liner is saging
    Email them, and the link to the thread, to me:
    poolforum AT gmail DOT com
    Ben
    Thanks, Ben. I sent you an email w/ pictures and the link.
    Blessings,
    Ted (TRHOD) North Canton, Ohio
    1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
    Acquired pool June 2006 Been BBBing ever since
    Thumbs up Re: J-channel holding liner in corner broke off, liner is saging
    Thank You for the pics!
    It doesn't look like J- Hook - which is a good thing.
    If I'm right, you may be able to install a small piece of 'side mount' flexible receiver to reattach the pulled out liner in that corner.
    There are some caveats in the process which I'll be happy to tell you.
    Ohio, North Canton
    Quote Originally Posted by waste View Post
    Ok Ted, educate me. I have NO idea what to do or where to start, so the more info you have for me the better. I'm not sure what the "side mount flexible reciever" is you are talking about, so fill me in with any and all thoughts you might have
    I'm sorry I don't know the part #s involved
    There is a receiver that side mounts with ~ 1/2" below the 'receiver track' to to screw it in.
    You ABSOLUTELY! have to keep debris from falling behind the liner - as you screw the new receiver on!!!!!!!!!
    Maybe others here can help you find the liner receiver (I am out of the industry, but might be able to call on one of my friends)
    Ohio, North Canton
    Ok, well that gives me an idea. I'll check w/ the local pools store to see if they have this. Does this screw into the steel wall???
