Results 1 to 3 of 3
Thread: Right light bulb?
    Rock Tavern, NY
    Default Right light bulb?
    I ordered a replacement bulb from Leslie's for our Hayward Sp-543 underwater light. Leslie's quoted me $17.45 - vs. $30-40 from the locals. The original bulb is a 500 watt, 120 volt r-40 type. Can this fixture take a 12 volt bulb?
    18x42 Spartan Roman End Vinyl Inground (1981)
    1HP Hayward Superpump -- Hayward Perflex EC-65 DE Filter
    Post Re: Right light bulb?
    Kirsten, the short answer is no, the 12 v bulbs are attached to a 10:1 step down transformer running 120 v to it would cause it to blow. Stick with the 500 w 120 v r-40, unless you want to get the transformer and have an electrician wire it for you.
    Rock Tavern, NY
    Default Re: Right light bulb?
    Thanks very much for the info! I will stick to the 110 volt bulb. Have a great weekend -
  1. Lower Watt Light Bulb
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 08-06-2012, 05:19 PM
  2. Fiberstars 6008 lamp (light bulb) replacement
    By rjmo22 in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2011, 11:48 PM
  3. Pentair Pool Light - Halogen Bulb Question
    By jpmorgan12 in forum Pool Equipment & Operations
    Last Post: 06-18-2010, 10:17 PM
  4. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  5. Fiber optic bulb replacement
    By Bobster in forum In-Ground Pool Construction and Repair
    Last Post: 07-10-2006, 09:55 PM
