Results 1 to 10 of 18
Thread: First time Startup of 24' AGP
    Jul 2012
    Pennsylvania
    Default Re: First time Startup of 24' AGP
    Today is 1 full week of adding the Kem-Tek Dichlor. I did a Full panel of tests including CYA. I added the final PM dose of 1 1/3 Cup last night at 9pm. This reading is exactly 12hrs later with having run the Filter for approximately 3.5 hrs during the night.
    Temp - 75
    FC - 11
    CC - 0
    PH - 7.4
    TA - 80
    CH - 40
    CYA - 40
    Did not add any more of the Dichlor and now I believe I can switch to the BBB method for rest of pool season. Also wanted to point out that I believe I made a mistake in the size of the pool. I do not have measuring tape that is long enough and was basing the size on some old documents I found in basement. I walked the pool using one foot directly in front of the other and came up with 27 steps. I am a size 13 so that roughly one foot each step. Know that sounds ridiculous but should be somewhat accurate. So I need to make all calculations based on a 27' X 4' Round AGP.
    Do I need to add Borax and Baking Soda to Increase the TA and PH or are the levels fine where they are? From what I have read I think I need to add 1.4lbs of Borax to bring PH to 7.6 and 2.2lbs of Baking Soda to increase TA to 100.
    What should the TA and PH be in regards to my other readings and are they fine at the current level they are at?
    Is there a way to calculate dosages properly for future reference. I am having hard time locating the PPM level change for X amount of either Bleach, Borax, and Baking Soda based on my Volume which should now be 17132 gallons.
    Pool water is still clear and have had no issues with any type of smell, slimy walls or cloudiness. Running the pump on a cycle of 2.5 hours on and 3.5 hours off continuously for a total of 10hrs a day . Have not needed to Backwash the Filter at all as of yet. The Psi has only increase by 1 for the week according to gauge on pump. Right now the FC is high but will not add bleach till necessary. Would just be nice to know how much to add to increase 1ppm. Thanks!
    24 round 15.3K gal AG vinyl pool; hand fed granual; XPUSA 16" 6 way Valve sand filter; XPUSA 1 HP Pump pump; Taylor 2006; well; summer: solar; winter: none; android phone; PF:7.8
    Quote Originally Posted by PaPoolNewB View Post
    1. You might get a more accurate measurement, by measuring AROUND your pool, and then dividing by 3.14 (∏)
    2. In a vinyl pool, CH is not important. TA only matters if you are having problems controlling your pH. If your pH is reasonably stable, I wouldn't bother with any TA adjustment.
    3. Trying to calculate doses for pH change is NOT a good idea. If you really need to do that, use the K2006 acid or base demand reagents, and their dose tables.
    Otherwise, that's what the PF does. Your PF is 7.8, which means that it is 1/7.8 of a 1,000,000 lb pool (~120,000 gallons). When you add 1lb of a 100% chemical, like stabilizer, you will increase that level by 7.8. So, 3lbs of cyanuric acid in your pool will increase your CYA level by ~23 ppm (3 x 7.8). Plain 6% bleach has about 0.5 lbs of chlorine gas in it, so each gallon will add about 4 ppm of chlorine to your pool (7.8 x 0.5). Dichlor is about 55% chlorine & about 50% CYA (no, I didn't make a mistake; no, I won't explain: trust me, you don't wanna know -- has to do with old water treatment custom!). So 1lb of dichlor in your pool will add about 4.3 ppm chlorine and about 3.9 ppm CYA.
