Thread: pool ladder too short
    Aug 2012
    Iowa
    Default pool ladder too short
    just had my Doughboy pool set up, 16'x32'x 54"
    deck is being built around 3 sides and almost done with deck boards.
    Deck built above wall height of pool, approx. 62" to top of deck board from ground level, and 8 inches above the pool wall.
    Now my problem, just put the ladder together, a #7000 Confer plastic's brand.intended to deck mount.
    They don't make extensions long enough.
    I wanted a little room above pool wall, 2 '' and using larger lumber for joists it really raised the deck walking portion.
    Anyone have an idea?
    Gonna look silly with deck stairs only to use ground level ladder.
    I can only find ladders that go to 56" or so.
    jwhouse is offline Registered+ Thread Analyst jwhouse 0
    Jun 2012
    Southeast Louisiana
    Default Re: pool ladder too short
    Quote Originally Posted by rajung View Post
    I guess you could use steps instead of a ladder. The top step out will be a little long though but it might beat the ladder.
    30' round 22K gal AG vinyl pool; skimmer tabs and GV Bleach; Hayward SD60 sand filter; Pentair 1.5 HP pump; hrs; ; utility water; summer: none; winter: none; K-2006 Test Kit ; PF:5.5
  1. In ground pool remodeling - short retaing wall
    By Chris b in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2013, 06:12 PM
  2. Seeking help with new pool- sand filter works barly for short time and no pressure
    By tallguyy808 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2012, 09:23 AM
  3. Confer Pool Steps too short to reach deck. Any ideas?
    By Holly in forum Above-Ground Pool Construction & Repair
    Last Post: 04-20-2012, 02:38 PM
  4. pool ladder floating
    By SHOVELHEAD in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2011, 10:35 PM
