Thread: What did I fail to do?
    Default Re: What did I fail to do?
    Have you been running the pump while your solar cover has been on the pool? If not, do so. Aim the eyeball down away from the surface so it won't push your cover out of place but do run the pump.
    Jun 2012
    Las Vegas
    I did but obviously not long enough. I had been running it all day everyday for 3 weeks to clear up the original green soup mess and after it was clear I thought I could get away with a just a few hours a day.
    On a side note, I'm starting to realize that it would have been much easier and cheaper to just drain the pool and refill when I first pulled the cover off. I spent more on chemicals than what the water would have cost to refill, not to mention all the time spent having to clean the filters 2 or 3 times a day as they got clogged up pretty fast. The only downside is I would have to buy/rent a water pump as my system has no backwash or drain to outside of the system. The ground is really dry here in Nevada so there is not much risk having an empty pool for a short time. Live and learn.
    16x32 free-form 18.6K gal IG concrete pool; new owner, none yet; Purex Triton Mytilus FMY-150 DE filter; Pentair WhisperFlo 2 HP 1 speed pump; 8 - 12 hrs; gas heater, spa; Taylor K-2006 from Amazon; utility water; summer: none; winter: none; iPad; PF:6.5
