If you normally run the system in spillover mode and isolate and heat the spa when you want to use it (the most usual setup) then the water chemistry is the same for both.
In that case just test and balance the water when in spillover mode (after it has circulate for a few hours) and you are good to go. IF the spa gets very heave use (such as at a party) you might want to shock it and let it circulate for a bit before switching back to spillover mode.
