Results 1 to 8 of 8
Thread: Hayward super pump 3/4 ?s
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Default Re: Hayward super pump 3/4 ?s
    So what kind of gauge IS salt compatible?
    Thanks--
    membership updated.
    Do check the gauge . . . especially if you've used a salt system. I recently discovered that 99+% of the gauges sold into the pool market are NOT salt compatible.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
    BigDave's Avatar
    How about: get a new gauge every year?
    Jun 2013
    Ohio
    well after more inspection of the pump housing I have found a crack. I welded it up and am hoping tonite when i reinstall pump that the problem is solved. I think the crack may have been sucking air and this may have been causing my probs. thanks so much for the insight great site. Unfortunately I'm sure i will have more ?s later thanks again
    Quote Originally Posted by Messina1974 View Post
    later thanks again
    Glad you were able to solve your problem!
    Quote Originally Posted by drband View Post
    So what kind of gauge IS salt compatible? Thanks--
    These are:
    WIKA Industrial Pressure Gauge with Stainless Steel 304 Case and Stainless Steel 316L Wetted Parts
    As long as you don't let them freeze with water inside, these will last indefinitely. They are also much more accurate than typical pool gauges. I'll try to get back to this thread and post specific gauge recommendations out of that list.
