Results 1 to 10 of 11
Thread: How can I replace fitting in the wall of my pool for the pool cleaner
    Jul 2013
    Dallas
    Default Re: How can I replace fitting in the wall of my pool for the pool cleaner
    PoolDOc,
    Thanks for the help.
    The Pool side is good. No spray from that fitment.
    However, I can visually see water spraying under the decking. It appears to be coming from the edge of the shell or in the wall of the pool.
    With the booster pump on I loose 1 inch in a hour. With the booster pump off I still loose an inch a day.
    I have been told I have two main options. Go through the decking or drill the wall. As this is the most visible part of the decking I would say that going through the decking must be the backup plan.
    So if going through the wall is the only choice how can I drill out the fitment from the pool sidel? What will I encounter and how do I repair it so that it will last.
    I can understand that pool companies are busy but from the range of verbal estimates of $900 to $1200 I dont see this as a low profit repair. With the right tools I would WAG this would take no more than 4 hours.
    I will dig under the decking tonight and take more pictures.
    Derek
    Quote Originally Posted by DerekGJenkins View Post
    The problem is, you are never sure how long repairs done down in holes will take, till it's done. Things go wrong.
    Undoubtedly, the contractors are hoping to get it all done in 3 hours (plus an hour of travel and tool collection), but want to make sure that if it takes 8 hours, they don't take a bath. (They are pretty sure that, if you accept the $1200 quote, and it takes 8 hours, because of some issue not yet visible, that you won't be all eager to up the payment.)
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    I wouldnt be running that booster pump it will wash out base material, is it close enough to pool to get one of those cameras on a flex stick , they sell for about 80.00 . insert into pipe or drill hole in deck .
    Texas
    Marin is offline In the pool biz Thread Analyst Marin 2 stars Marin 2 stars
    Jun 2013
    Oklahoma
    I'd leave the deck alone and go under it, as you've started doing. Hopefully the leak isn't too close to the gunite where you're chipping it back to make a coupler work. This one actually looks fairly easy.
    As for the cost aspect, the only reason I even deal with fixing leaks is that I view it as an opportunity to earn future business. In itself it's really not worth the hassle. I can't just send one of my low skilled guys out. With leaks you need some experience to notice things not so obvious. So right off the bat I've effectively shut down one of my crews because I have a lead or foreman looking for a leak. Since I want to minimize his time dealing with it, I send a helper. Usually pays off but not always.
    Your leak looks simple, but things happen. If the pipe is fragile enough for one leak, whats to say we don't cause another getting everything snugged back up? I also have to account for future aggravation. There seems to be a mindset amongst homeowners that whoever was the last to touch it, did it.
    If another leak springs next season a few feet down the pipe, guess who's going to get blamed?
    I'll usually bid one anywhere from $700-1500, depending on location and deck. I generally treat it as a "not to exceed" bid and charge the customer less based on what we actually encountered.
    If you're comfortable making the fix yourself, I'd say it's an easy way to save a grand. The parts are cheap. If you want to do it, I'd be happy to help. I'll just ask for a couple more pictures, preferably one of the leak itself.
    Quote Originally Posted by Marin View Post
    Don't I know it!
    I'll never forget the lady who got mad at me for messing up her "plumbing". I'd repaired her toilet (I'm a plumber, originally) and the day after I left, her kitchen sink started leaking. She was furious, when I refused to repair it for free!
    In her mind, I'd worked on the "plumbing", and after I left, something went wrong with the "plumbing". Ergo, I did it. There was no arguing with that.
