Results 1 to 10 of 15
Thread: I've used HTH algaecide - do I need to drain my pool?
    Default Re: I've used HTH algaecide - do I need to drain my pool?
    50K gallons is a HUGE residential pool, and very unusual. A 30 x 60 lap pool with 4' ends and a 5' center would be only 57K gallons; a 20 x 40 block wall pool with a 4' shallow end, 12' flat deep end, the break at 10' from the shallow end and a flat bottom straight wall deep end would be only about 45K gallons.
    Please measure the pool's dimensions. It's hard to dose correctly, with incorrect volume calculations -- but about 30% of pool owners use seriously incorrect values.
    Aug 2013
    Dallas, TX
    So, you're right. I re-did some rough calculations today. My pool is two heptagons (7 sided) joined by a rectangle (it's a custom made pool). It's apparently roughly 2100 square feet so it's roughly 15.5k gallons. Still waiting on my kit.
    Aug 2013
    Dallas, TX
    I got my K-2006 kit. FC - 0; pH- 7.4 ; TA - 90 PPM; Cyanuric Acid < 30 PPM
    1. Add 1 gallon of bleach EVERY night, for now. Skip if the PM chlorine result is dark yellow (OTO) or more than 3 ppm (DPD-FAS).
    2. If you have access to Sams Club, purchase (2) 24# paks of bagged dichlor. This will add BOTH chlorine and CYA, but since it's bagged, what you don't use this year, will last till next year without getting all stinky.
    3. pH => OK; TA => possibly low, but don't fix it yet. CYA => low. Calcium => needs to be tested. Since you have a concrete pools, you DO need to worry about "water balance" or "saturation index", which is a composite calculation involving pH + temp + TA + CH. If you have heater, it needs to be managed even more carefully.
    Aug 2013
    Dallas, TX
    I understand you want me to use dichlor to increase both CYA and Chlorine in my pool. However, I don't have a Sam's club membership. Is there an alternative you can recommend?
    Kem-Tek dichlor 2 lbs @ Amazon => ~$6.50/lb (Jul 2013)
    Kem-Tek dichlor 5 lbs @ Amazon => ~$4.50/lb (Jul 2013)
    Kem-Tek dichlor 12 lbs @ Amazon => ~$4.00/lb (Jul 2013)
    Kem-Tek dichlor 22 lbs @ Amazon => ~$3.60/lb (Jul 2013)
    Looks like they are out of stock on the 22#, so the 12# is the largest you can get.
    Two other options:
    + I think you may be able to get a 1x trial membership at Sams -- call and ask.
    + Home Depot sometimes carries the KemTek brand. But, Kemtek now makes dichlor goop, too. So if you want to check out Home Depot, print the pictures from Amazon, and make sure what you buy is EXACTLY the same.
    Hm-mh, Kem-Tek has updated some of it's labels, and I found a picture on Costco, so apparently Costco may carry this in some parts of the US, though not here. Anyhow, here's their current (Aug 2013) label:
    If you decide to get dichlor from any other source, you probably want to post EXACT brand and product name here first: about 90% of the sold now is some sort of goop mixture.
